RJMII
Jun 23 2009, 07:47 PM
progress
RJMII
Jun 23 2009, 07:48 PM
pregress
RJMII
Jun 23 2009, 07:49 PM
progress
RJMII
Jun 23 2009, 07:51 PM
1/0 battery cables. =o) That ground cable is going to the side of my engine block, the starter WILL be getting enough electrons.
RJMII
Jun 23 2009, 07:52 PM
front end shot.
RJMII
Jun 23 2009, 07:54 PM
I started pushing the corner out and straightening some sheet metal.
RJMII
Jun 23 2009, 07:55 PM
... and this chunk of bondo popped out of the metal. Looks like I might have enough to go on for straightening it out to 'functional'
RJMII
Jun 25 2009, 10:21 PM
RJMII
Jun 30 2009, 08:47 PM
JRust
Jun 30 2009, 08:58 PM
Oh I get it! Today you did nothing
RJMII
Jun 30 2009, 09:29 PM
noT a single THing.
ghuff
Jul 1 2009, 01:13 AM
Good call on the 1/0 cabling. These cars like most VAG products and euro cars of the era suffer from poor electronics.
Hell even my 01 GTi has a piss poor grounding system and electrics.
I cleaned up a bunch of grounds on my 914 when I was cleaning metal, and since they were disconnected I cleaned the spade connectors/ring terminals. The car ran noticeably better than it did before.
I imagine with a modern ECU that is sensitive to voltage drops and a little more complex than D-jet/L-Jet you would have some issues.
Next stop is to add some more grounds and clean more grounds.
JRust
Jul 1 2009, 01:27 AM
QUOTE(RJMII @ Jun 30 2009, 08:29 PM)
noT a single THing.
Hey when I posted that your video was just a blank white box
Nice to hear it run. Now lets see it propel you down the road
RJMII
Jul 1 2009, 01:38 AM
QUOTE(JRust @ Jul 1 2009, 01:27 AM)
noT a single THing.
heh. I have to pull the transmission away from the adapter plate and see what is binding inside of there. it will propel me, if I start it in gear and don't plan on shifting.
oh yeah, I had to adjust my youtube tag again. the first vid in this thread has the _ and the second vid doesn't. rather weird, but it's working now. (side note: thank you again to the admin that provided me with some assistance in getting me on the right track.)
RJMII
Jul 1 2009, 01:46 AM
QUOTE(ghuff @ Jul 1 2009, 01:13 AM)
All of my computer electrics and sensors ground directly to the block, or to a nice clean spot that I made for grounding point where my rear trunk spring use to be.
Next is to zip tie a spaghetti mess next to the engine...
That reminds me; I cleaned up spaghetti mess in the front trunk. I changed the wiring harness and now have functional lights for all four corners again. High beams, low beams, turn signals, flashers, brake lights, back up lights, tail lights...
the ground points all seem to be doing well from cleaning them. =o)
RJMII
Jul 2 2009, 10:26 PM
I ran into problems with my clutch not disengaging.
The transmission had to come out, then the bolt with the ball on the end of it needed shimmed out a couple of washers, and I had to change the retainer plate that goes on the back of the clutch arm. (or whatever it's called)
I've been up since 4, and it is now 9:30. I managed to get the transmission back in, all of my wiring cleaned up, the car pushed out fo the shop, and had it started and idling a little.
I'm having fun getting MS-II to have the right settings for all of my Chrysler sensors. MegaSquirt comes ready to go with GM sensors...
so the deck lids are back on in case it rains, and here is a pic from the day.
Oh, and I drove it five foot. =o)
RockinOldSchool
Jul 2 2009, 10:31 PM
QUOTE(RJMII @ Jul 2 2009, 07:26 PM)
Can't wait to see a vid of it out on the road!
JazonJJordan
Aug 24 2009, 12:28 PM
? wait...does it have a black eye?? Must be a fighter getting back up and V6 turbo fighting mad! Keep up the great work!
QUOTE(RJMII @ Jun 18 2009, 07:29 PM)
Yes, the hammer is holding the bumper on. Just the hammer, gravity, the front valance, and that @#$%# bondo. =o)
RJMII
Aug 24 2009, 12:41 PM
Right now both of the eyes are out; I need to get some more hardware/screws etc from the parts car to put it all together.
current status:
The car is on jackstands waiting for some wheels and tires. It is also waiting for a silicone elbow to go to the throttle body from the piping where the intercooler should be. The rubber one blew apart from heat and pressure. wuahahaha
Then I'll get the video of it taking off. (with a not so optimal tune, but it still takes off)
I guess I've been too busy driving it around town tuning it to post updates.
RJMII
Sep 8 2009, 07:28 PM
jsayre914
Sep 8 2009, 08:36 PM
great work
dlee6204
QUOTE(SGB @ Sep 8 2009, 10:21 PM)
AWESOME!!!
RJMII
Sep 19 2009, 12:00 PM
I ran into a few problems a couple of days ago.
After a long day of having my 4 year old with me, we got into the car to get ready to come home.
He was sitting in the booster seat in the passenger side, and I had just set the laptop up to get a datalog on the way home. I set it down on the floor board in front of him and while setting it down it somehow made contact with his feet and it shorted something out and screwed up my firmware and fuel map.
I didn't realize it had screwed something up, and we started heading home from my parents' house, and got off of their street and turned right to head into town. Just as we were pulling out of first gear the (screwedup fuel map) caused a backfire and my car started running quite loudly in a big hurry. (it had blown the exhaust off just after the down pipe)
There was a shop rag in the car, I used it as an insulator to grab the exhaust and toss it in the front trunk. (It's only 3 foot long)
I got the exhaust back on, the car ran like crap... I had to reflash the firmware and have been trying to get it tuned back in since.
Last night I did a tuning session out on a farm road (that is paved) I was slowly working my way up through more and more pedal. On one of the runs I hit 16.7 PSI with NO detonation!
(and This was all at less than 70% throttle)
It had the boost, but it was getting too much fuel in the mid-RPM range, so it was a *ahem* slow acceleration.
RJMII
Sep 19 2009, 12:34 PM
The ambient air pressure last night was 66.95kPa; and the highest peak of the blue line was 202.8kPa... the math came out to be around 16.7psi.
The purple line is TP(Throttle position) It looks like I need to adjust the TP sensor calibration. (I floor it with the clutch pushed in to burn off any excess fuel from running a rich spot. This takes a split second and gets rid of the fuel that might cause wet walling)
..and the yellow line is the RPM. This graph shows me going from about 0-60ish in first and second gear. The bottom of the slant on the yellow line before the first peak is at 3878 seconds, and the top of the peak after the shift is at 3885 seconds.
RJMII
Sep 19 2009, 11:19 PM
my car is currently aircooled and not going anywhere w/out a trailer. =o(
rick 918-S
Sep 19 2009, 11:26 PM
happened?
RJMII
Sep 19 2009, 11:40 PM
I took my wife to the movie tonight. It was a perfect evening for a ride with the top off, we had a baby sitter, so we went to the movie.
We were driving along and heard a 'thunk' under the car, something must have snagged the cooling line or hit it just right to knock it loose enough to cause some damage. It had rubbed a little before and I secured it... but appearantly not enough to keep whatever I ran over from poking a hole in it.
We were almost home when we heard the kerthunk, and I looked under the car to see it peeing. We came right home and parked it, so no overheating, just a big, ugly, green, mess.
RJMII
Apr 21 2011, 04:09 PM
I should update this thread...
The coolant leak pictured above was easily repaired once we got the car pulled back to the shop.
In November of 09 I hit a boost spike in the single turbo engine. This caused a minor amount of damage to the seals in the turbo, so it started seeping oil into the intake from the turbo.
This didn't really get noticed until it blew and started dumping oil into the intake and the engine lost oil pressure, taking out something in the bottom end. It now has this clatter in the bottom end. It still propels itself, but rather than drive a knocking smoke cloud generator, it just sits outside as a decoration.
In Sept of 2010 I located a 3000GT VR4 engine from a 95 (it has 4 bolt mains, an internal crank position sensor, two turbos, cam position sensor, and I can easily get 450hp by changing to headers, slightly larger turbos and bigger injectors)
There are a few little bits and pieces I need, and have acquired a few already, including a BOV to avoid pressure spikes.
I'd really like to drive this thing again this summer, so I'm putting all I can into getting my health in order to where I can get back to milling and to where I can rebuild my spare transmission to turn around and sell.
RJMII
Jul 11 2011, 07:13 PM
well after lots of personal shit stuff happening that has really screwed with my head and ability to focus, I decided to put together pieces parts that i've been gathering together. It's been great therapy. Driving it again will be even better therapy.
Here's a teaser picture or two.
Mike Bellis
Jul 11 2011, 07:17 PM
That engine looks massive! More pics please...
RJMII
Jul 11 2011, 07:23 PM
QUOTE(kg6dxn @ Jul 11 2011, 07:17 PM)
pic your angles.
I'll get some tomorrow
iamchappy
Jul 11 2011, 07:42 PM
Dont give up the ship, your still in the R & R stage, shit happens and will continue to happen but it all gets worked out in the end.
I worked through many problems myself and still am, i am close but wont really know for a few hundred miles more. If things dont work.... well, back to the drawing board and try to come up with a better idea.....
FourBlades
Jul 11 2011, 08:56 PM
I love the 3000gt engine. I had a dodge stealth the first year they came out and later had a 3000gt. Never had a turbo car because they were $ back then.
That will be wicked fast when you get it dialed in.
John
Dr Evil
Jul 11 2011, 09:01 PM
Not too tight, just use one of these to get the engine in
RJMII
Jul 11 2011, 10:25 PM
QUOTE(iamchappy @ Jul 11 2011, 07:42 PM)
the problems aren't with the car...
R&R stuff and solving issues with the car makes it relaxing and good therapy.
FourBlades: I've been drooling over the MS-III upgrade for my MegaSquirt... dialing it in is goin to be fun.
Evil; YES! I knew I was missing a tool while putting that in there.
RJMII
Jul 12 2011, 04:41 PM
pics
RJMII
Jul 12 2011, 04:43 PM
more pics
RJMII
Jul 12 2011, 04:45 PM
and last pics for today.
The engine lid and trunk lid both close, and there are a few pics of how much room I have in front of the engine and to the sides. The really wide valve covers just make the engine look like it was super tight fit.
We had the engine and transmission on jackstands and lowered the car down onto it with the hoist.
AgPete139
Sep 12 2011, 01:46 PM
Any updates?
JRust
Sep 12 2011, 02:02 PM
QUOTE(AgPete139 @ Sep 12 2011, 12:46 PM)
Any updates?
IT is up for sale in the classifieds. I don't think Jim has had much time to work on it. He's had alot of personal stuff going on. So the 914 is way down on the totem pole.
RJMII
Apr 11 2012, 09:32 PM
This is the engine mount that was holding the 2.5 in place. It had diagnal pieces going up to the sides of the blocks. I think the torque might have bent the bar a little... the aluminum from making some emblems is in there as a 'straight edge reference'
This one is a little thicker walled:
And what happens when you put too much weight on a 911 sport mount without the cupped washers:
(I need 4 cupped washers, if anyone has some extras)
nsr-jamie
Apr 11 2012, 09:49 PM
So you are not going to sell the car? I hope you get to finish the project. It would be great to see. Take it easy.
RJMII
Apr 11 2012, 10:33 PM
QUOTE(nsr-jamie @ Apr 11 2012, 09:49 PM)
Nope.
I am Keeping the car.
Mike Bellis
Apr 11 2012, 10:53 PM
Dr Evil
Apr 12 2012, 07:17 AM
Good to hear, Jim
RJMII
Sep 17 2013, 08:44 PM
did a little bit of work... :-)
rick 918-S
Sep 17 2013, 08:55 PM
RRC 14?
RJMII
Sep 17 2013, 08:58 PM
Spaghetti is looking a bit less saucy and more conducive to electron exchanges.
RJMII
Sep 17 2013, 09:01 PM
QUOTE(rick 918-S @ Sep 17 2013, 08:55 PM)
RRC 14?
I hope so.
maybe even that route 66 deal or something... who knows.
