...it is all concentrated in the middle. Like the 944, 968 or 928, this makes for a well-balanced, neutral handling car. However, as opposed to the others, it has a very low polar moment of inertia, which has two significant effects on its handling. It tends to be susceptible to crosswinds, and on slippery surfaces it rotates extremely quickly. - Vic Elford - High Performance Porsche Hand Book - Page 55.
Eric, thanks for posting this--it's important . . .
It's easy to forget that the 914's quick "turn-in" also means it can spin in a heart-beat. Its relatively low moment if inertia also makes it easy to over-correct and start a spin in the opposite direction (BTDT
Basically, the moment of inertia of an object describes how easy it is to change its angular motion about its axis of rotation. Even if a 924/944 had exactly the same mass as a 914, it would require more effort to change the 924/944's angular motion because its mass is distributed further from its axis of rotation. That also means that a 75/76 914 with the big/heavy bumpers has a slightly higher moment of inertia than an earlier car.
Food for thought I guess
Thanks again--and sorry for the hi-jack.
