I have the following located in Mundelein IL
Steel hood
Steel Trunk
Steel Doors
Steel engine lid.
LM1 Air Fuel Ratio meter and data logger. NEW $150
911 Engine mount $20, one with jack / tow and other stock
911 Engine cross member engine mount $20
911 5 lug rear hubs $100 have swing arms but can disassemble if you just want 5 lug
914 stock 4 lug front and rear with brakes. Nearly new rotors just surface rust from sitting in shop. $50 a set
225mm 911 flywheel, starter ring, sachs clutch $50 each
Front A arms $10
Steering Rack $25
gas pedal $5
clutch / brake cluster $25
Oil Cooler for 914/911 -10 male fittings 21 1/2 x 4" $100
Couple aero quip fittings
