FS various 914 911 parts, From race car conversion |
dougcoup |
Nov 16 2008, 01:08 PM
Member Group: Members Posts: 131 Joined: 5-March 05 From: mundelien, il Member No.: 3,715 |
I have the following located in Mundelein IL
Steel hood Steel Trunk Steel Doors Steel engine lid. LM1 Air Fuel Ratio meter and data logger. NEW $150 911 Engine mount $20, one with jack / tow and other stock 911 Engine cross member engine mount $20 911 5 lug rear hubs $100 have swing arms but can disassemble if you just want 5 lug 914 stock 4 lug front and rear with brakes. Nearly new rotors just surface rust from sitting in shop. $50 a set 225mm 911 flywheel, starter ring, sachs clutch $50 each Front A arms $10 Steering Rack $25 gas pedal $5 clutch / brake cluster $25 Oil Cooler for 914/911 -10 male fittings 21 1/2 x 4" $100 Couple aero quip fittings Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 03:52 AM |
