Hi All,
I have my 1983 Porsche 928 for sale. It needs a tranny and a little tlc.
You can email me at futuresoptions@rgv.rr.com if interested. Thanks
1983 Porsche 928 Euro Information
The car I have for sale is a 1983 Porsche 928 Euro. The car no longer has the Higher
horsepower Euro motor in it as the previous owner installed a 1979 non-interference
motor. The car has a 3spd auto transmission installed, and has a little over 107,000
miles on the odometer. The car had been stored for 7 years prior to me purchasing it
and the motor starts and runs fine.
I will list below the qualities and deficiencies of the car below and allow you to decide
if she is right for you.
The Good:
Good solid project car.
Motor starts and runs
Installed new universal ignition switch
Installed new parts to where drivers door will open from outside
Rebuilt rear cv shafts on the tranny side
Installed new timing belt, cam gears and all front enging seals
Installed new water pump
Installed new fuel pump and fuel filter
Installed new aluminium radiator
Installed new transmission cooler
Installed new transmission lines
Installed new vacuum lines
Installed all new belts
Installed new hoses
Installed new battery connectors
A/C compressor works and blows cold
Power steering pump works
Have new wiper blades and Oil filter that need to be installed
Gauges working last I checked
seat motor is good
Power window motors good
The Bad:
Car looks okay, but will need a paint job, has some cracking in the paint and has some rust issues
around the rear spoiler, but nothing major. Has a couple small dents.
A/C works but on defrost only.. will need to repair/trouble shoot the controller
Interior is okay, but will need to be redone to be perfect. Dash is cracked.ABS
dash toppers are availible for this model.
Some vacuum lines on the motor still need changed out.
Will need new tires
Needs universal oil cooler
Needs 2 radiator hoses (have 2 installed, but they dont fit quite right)
Needs spark plugs
Needs front spoiler (did not come with one)
Needs tranny rebuilt or replaced (moves forward in 1st gear,
but will not go to second or third, will not go into reverse.)
Needs new window, sunroof and rear wiper swiches ( are in place, but gutted)
Winshield is good, but has one dime size chip on drivers side
Will need various electrical pieces probably, relays, switches...(Haven't gotten that far
with the car to tell exactly.)
Conclusion:
Good solid project or parts car... I really would just like to get her out
of the car port at this time... I have $5200 invested in her, Will take $1000. firm Let me know if you are
interested
Regards
Bill
