Slapping together a 1911 over the next month. The car is a 71, with a few pounds off ( fiberglass bumpers,soundproofing removed et...)
It's a seasonal driver that get some AX time in. Bilstein sports, 19mm front sway, 911 front a-arms with 19mm t-bars ans Eibach AX rear springs, turbo tie rods,et....
I have an EA case that I'm doing the galley plugs on and building up to a carb'd 1911
Along with all the new p&c's I have
1.7 and 1.8 heads. The 1.7's have been flycut & opened for 96's. I'll probably flycut the 1.8's for larger valves
36mm Dell's and 40mm Webbers I know Jake likes the Dell's for this combo
Even though I drive the car on the road alot I like a fast spinner. What can you guy's suggest for cam's? I'm thinking of working with a compression ratio of around 8.5 to 9.?
Have you built this one? What did you do for cam, do anything different next time?
Thanks & Happy New Year
