QUOTE(FourBlades @ Jan 15 2009, 09:48 AM)
Leave the tunnel in place if you can. I removed mine because the rear part was
totally shot and beyond repair. I got a rear half from someone sawzalling a car
and grafted my front to it. Then I spliced it all back together. This is lot of work
so I would not do it that way unless you have too. If your tunnel is ok where it
connects to the floor, then just drill all the spot welds out to remove the floors.
You probably need to replace the brake and clutch tubes. I removed my heater
tubes because that is the last thing you need in FL...
John
The left side flange on the tunnel is gone. The right side has multiple overlapping patches and has been seam welded to the floor. It has also been opened up on top in front of the shifter area.
I was a little angry before my previous post. Having calmed down, and taken a second look, the tunnel can "probably" be fixed. The floor will be changed, though.
P. S. On a day like today I would have used the heater tubes.
