Wow congratulations on a successful build
Why not SDS?
They do a lot of Subbies, an you have liked their product, know it semi well, and they can fill in your lack of knowledge on the Subaru side. Are there more convoluted systems out there, YES! Are you try to eke the last 10th of a HP out of a daily driver, most likely not. An NA Subaru 2.5 will be a 50% improvement on power if not more. A 3.3L will take you to 150% More Power!!! And you get into the turbos 200-300% More power. And that is with out going
Or you could learn an entire new setup, nothing wrong with that.
I have been an SDS fan for years, and see no reason to go away from it, unless you want or need functionality it does not offer.
Things that could pull you away.
Launch Control
Staged Injection
Dual Fuel - Dino gas / E85
I know there is more, but Im not thinking you need multiple boost control, with methanol injection, and a NiOx Controller, and automatic shifting.
I would love SDS to run dual fuel, but then, that is not really an issue for me, it is a want.
You would need to upgrade your unit to run coils, and since you have a 4-cyl. unit I would stick with a 4-cyl. Subaru engine.
That being said, I am sure someone would be happy to buy your complete drive train and plug an play their car. Can't wait to see the build threads
