QUOTE(ConeDodger @ Feb 10 2009, 04:31 PM)
Leamon is correct. The 6 peddle clusters had a hand throttle tab at the throttle peddle area. If you are putting this on a 6 conversion, you are unlikely to ever find a 6 peddle cluster for sale. Remember, there were only 3400 or so 6 cylinders produced. If you have a 6, use your cluster and have it rebuilt.
Using the 4 peddle cluster means you will have no hand throttle and will have to warm the engine with your right foot...
Thanks for the clarification, Rob. Since you already have Jerry waiting in line, I'll pass, just because the /6 project I'm buying comes complete, so I should rebuild the original cluster with proper hand throttle tab. Might as well do it right. Sorry for jumping the gun early.
-duc
