Start by tucking into the factory shop manual circuit diagram (which can also be found in the Haynes manual).
The diagram designates connection points and their location in the vehicle.
QUOTE(bobhasissues @ Feb 15 2009, 06:36 PM)
My '74 is blowing fuse #9 when I use the right turn signal. It also blows #11 when I turn on the hazard lights. It appears something is shorting along the passenger side turn signal circuit(s) but I don't know where. The bulbs are good and the sockets are clean. I have two working flasher relays and get the same result with either relay. I would like to disconnect the front and rear signal circuits as close to the flasher relay as possible and test them individually to see if the short is in the front or rear circuit, but I don't know where to find the junction of the front & rear of this circuit. Any advice or another strategy to weed this out would be greatly appreciated.
