QUOTE(Phoenix 914-6GT @ Feb 25 2009, 10:23 AM)
There has been many o threads about this as of late. You have many options in what you can do. You can do the whole 944/ 914 axle. You can do the 911 CVs on sway away axles. You can do a few others as well. It all cost money though. Just look at all the threads and see what you find for as little $ as you can Search the 911 boards and see what parts they all have and who knows how little you may get away with spending.
Sway Away also makes axles in various lengths that could be used with the 944 (type 4) CV's, which are 33 spline count axles (the 911's are 29 spline, stronger, and sway away has a larger selection).
One word of caution should you buy an axle assembly -- GNK Lobro is the major supplier of quality CV's and axle assemblies. They seem to want to use 25 spline axles as a standard. It doesn't matter if you use the axle assembly complete (CV to CV), but if you want to change things around, you may be limited to a 25 spline count axle.
Wes
