QUOTE(charliew @ Mar 11 2009, 07:59 AM)
I put the clip back on and the wheel wouldn't go all the way down far enough so I am not using it.
Sorry I went back and saw where you must mean the clip that holds the bearing in. I also noticed that you are using a vw bearing sleeve. On my 75 the metal bearing sleeve wasn't tight enough to keep the shaft from wiggling so I had to use the nylon factory sleeve as it is thicker.
Actually, I do have the bearing clip, it's the clip closest to the steering wheel itself I was referring to. My adapter arrived today but no directions in the box. However, there is a not in the box that says "Warning" "Do not install without reading the instruction manual"
...must be made in china.
