I set up the lines on my 76 using this diagram
http://www.pelicanparts.com/914/technical_...4_20FI_diag.htm
It's pretty close to what I have with my decel valve lines slightly different.
My car runs perfect.
My question invloves the distributor line. As stated I have left it open and to be tidy I zip tied the line to the fuel line that runs right by. I made sure the line was tied snuggly but still open and breathable.
So.. will this pass SMOG? I am just worried that when a tech sees a vacuum line going nowhere they are going to fail it until it gets properly routed.
I originally T-d the line onto the 6mm decel valve line that connects to the manifold nipple very near the distributor, but that made the engine idle at 2000 rpm.
Suggestions?
Thanks!!!!!
