QUOTE(Eric_Shea @ May 1 2009, 11:48 AM)
Changing over to a 911 front suspension will make your car handle worse!
Why?? Well they weigh more and you really want to reduce the unsprung weight as much as possible.
That's exactly why they were installed from the factory on 914-6's, 914-6/GT's and 916's... to make our cars handle worse.
914 rotor with inclusive cast iron hub = ?
911 rotor with aluminum hub = ?
914 caliper = ?
911S Caliper or Brembo caliper = ?
Next myth?
Eric;
Bad day fishing?
Quite frankly, I'm not really old enough to have been present when the Porsche engineers (or bean counters) were deciding on what components to use and why. I don't know. My guess is that they felt the Porsche version should have better brakes than the VW version. Maybe the thought was that with only 88 horsepower, the VW version didn't warrant the cost.
As for weight, I'd bet that the complete 914/6 strut assembly weighs more than the 914/4 assembly. (I just last week threw away a pair of 914/4 struts, so I can't do a weight comparison)
Both had iron calipers and the 6 version was physically larger, thus heavier.
The vented rotor was larger in diameter and thicker, although "vented" I'd bet per square inch of surface area it has more mass.
The aluminum hub on the /6 would be a plus over the cast iron hub section of the /4, but when you factor in the mounting flange area of the vented rotor, I'd bet it's a wash.
Are the /6 (and 911) struts beefer, and heavier? I don't know, but from what I understand you can't install a 911 hub on a 914 strut.
So unless weights are posted, the weight "myth" still seems valid. Comments about aluminum calipers or brembo's are not valid if you want to refer to what the factory did with the /6. Plus the fact that most reasonably priced 911 swaps have the iron calipers.
If mixing parts around is allowed in the discussion, then MichaelN's set-up with Alfa GTV6 aluminum calipers and billet hubs would be the weight winner (and with larger bore calipers to boot)
All that behind, I think SirAndy said it correct when he commented on the stiffer torsion bars, sway bar, and turbo tie rod links. All of which could be added to a 914 set-up.
(And I wonder why, at that Porsche engineer meeting, they decided that the 914 should have a through-body sway bar, while the 911 under-body sway bar was already in the parts bin. There must be some major technical reason behind it. I wasn't there at the time, so once again, I don't know. Maybe it causes some major safety issue when installed on a 914?)
Wes (I couldn't find a "stiring the pot" smilie) Vann
