QUOTE(Vacca Rabite @ May 9 2009, 06:48 PM)
QUOTE(orange914 @ May 9 2009, 08:58 PM)
205/65/15 are going to really be porky, do you think they'll fit the rear? you may have to roll/tug out the wells alot.
May be a little, but I doubt you will have to go out a lot. 205/60 15s almost always fit with the stock offset, though they are close. Roll the lip under, and I bet they work fine.
I'd be more concerned with the offset causing them to rub on the fronts when you are turning.
Zach
yes, i'm running 205/60/15, we rolled the lips and pulled the rear fenders a wee bit before paint but they are close... they have yet to rub front or rear but very close. 205/65 grows a tad wider as it gets taller (to keep the %). it would be nice though if it fit because it should be alot closer to the original height.
mike
