JRust
May 8 2009, 08:14 PM
Okay so I have a buick 215 v8 in my 70 914. I originally had overheating issues when I bough the car. Bad radiator setup overall. I then bought Renegades radiator setup in september. Just putting it in I had no heat issues when driving. That was mainly all hwy & I could hardly keep the motor warm. Weather was cooling off here then. It would warm up in town though. My fans would kick on at 190degrees like clockwork. Then parked for winter basically.
Finally started driving it again on nice weekend days. Again great on the hwy but would heat up in town. Never hit 200 according to my temp gage. Fans would come on at 190 still. Well I got to driving a little more in town & my temps started creeping up again. I called Steve at Renegade for some direction (Very helpful folks by the way. I've talked with him again since & he is always helpful). I had my cooling lines running thru my heater ducts. He says my water pump is working to hard trying to move all the water. Rerun your lines under the car & it will cut off the peak. Also it will make your lines shorter. All of which will make it easier on your water pump.
Sweet! So I get gates green stripe radiator line in 1 1/4 inch. I run my lines under my car in the recesses & hook everything up. Now my engine gets hot while my radiator stays cool. That was when I called Steve again. He gave me a few things to check. 1st was if I had my lines hooked up right. I say heck yes I am sure I got them right.
Okay so I had them backwords. I get them right & start burping the system again. Still have the same issue. Okay so next on hte list is to pull my thermostat (probably stuck). Makes sense except I forgot I didn't put a thermostat in. Not only that but when I unbolt it to find one not there I also find no water there.
1. Do I just have a big air pocket I am not getting out?
2. Is my water pump not pumping out enough water? I do have a great view of the belt turning it just fine
3. What the hell do I do next?
Sorry this is so long
. AS usual my simple things before WCR are not so simple. Help
andys
May 8 2009, 09:37 PM
It sounds like you didn't get all the air out of the system. It's not always easy to do and can be frustrating. I like to fill then momentarily pull the top radiator hose till coolant comes out; refill and repeat as required. I assume you have some sort of header tank as the highest point in the system; if not it's one of the fundamental requirements for success. By all means, do run a thermostat. I believe Rennegade reccomends drilling three small holes in it (for their sbc stuff). I would think they went through all that with you, no? Got photos of your cooling setup?
Andys
jaxdream
May 8 2009, 09:56 PM
I agree with the andys on the thermo , I put a radiator and thermostst in a 97 intrepid last year, what bbbb , therom had hole at top with a bb in it for air burping still , spit out about $15.00 worth of antifrezze.Took top hose off , poured frezze dow it til it filled , took thermo and housing off , filled it there also up to top , put back together , let run for a bit air burped out ok ,been running good since.Try the fill from thermo side , and maybe hose to rad till it comes out back at the engine. Good luk , they can be hair pullers
, but thats a part of em.
Jaxdream
rick 918-S
May 8 2009, 10:26 PM
Need more info. First, yes run a T stat. Drill a small hole in the face. This will allow trapped air through. Also check to see you didn't loose the pump impeller. Do you have circulation? How do you know. Do you have a temp gauge in the front on the radiator and one on the engine at the rear?
What does your front cut outs look like? Are you getting enough air out of the front trunk or trapping hot air in the trunk?
Sleepin
May 8 2009, 10:32 PM
Definetly sounds like an air bubble Jamie! You might consider jacking up the rear of the car (if you can get the water pump above the radiator). Then pull the hose off of the pump and keep filling until the air works it's way out. If that don't work, you can try it the other way and jack up the front of the car.
I don't have any experience with a 914 setup, have burped a few Chevys though.
computers4kids
May 8 2009, 10:38 PM
I spoke to Jamie earlier. When he pulled the thermostat housing he said there was no water, although he has filled and burped the system several times. I suggested there might be a large air pocket in the engine preventing the water pump from drawing and pumping...seems like it may need to be primed. I suggested filling the engine with water via the thermostat housing, cranking the engine and fill until till topped off. Not sure where Jamie is now on this.
He did crank the engine with the thermostat off and didn't get any water out the thermostat.
drive-ability
May 8 2009, 10:51 PM
QUOTE(rick 918-S @ May 8 2009, 09:26 PM)
I don't buy the hard working water pump crap, Its a pump, a strong one at that. if you don't have a T-stat your pump is likely fine, that's to say you didn't bend the fins. You likely have a combination of things now that you have changed out the lines. Air pockets can be a pain to move, every time I drain my system I will get a air pocket and you need to burp it out.. I would evaluate the exhaust cut-outs (need to be good size) and make sure your fans are turning correctly, that is voltage polarity and fan blade orientation. One other basic thing, your fans are being fed what they need, lots of amperage via wiring and alternator. I run my lines through the heater ducks and run a 200 amp alternator.
TC 914-8
May 9 2009, 12:01 AM
Hi Jamie,
My rod Simpson kit has instructions on how to fill the system. i'll have to dig them out, but... I remember reading something like disconnect the supply line to the radiator at the engine. connect a garden hose and turn it on. Water then flows thru the radiator, back to the engine, forcing all the air out of the system and block. Now, if the engine is running when doing this is another story, I can't remember. Once all the air is out of the system drain out a half gallon or so from the line going to the radiator, refill with 100% antifreeze. This should give you a good 50 / 50 mixture. Connect your line back to the engine and run it, topping off the system at the over flow.
assuming you have bleed ports and fill points at the highest point this thould give you a head start.
The point of drilling a hole in the thermo stat is a good one, helping bleed the air thru the system when the stat is cold.
Give me a call if you need me to dig up the Rod Simpson paper work, the Renegade folks should be your best bet and a good source since you have their radiator set up, plus they live in 120 deg all year long.
a hot day here is 74deg. My fan relay stuck on the other day and my temp gauge was reading 110, I had to pull over and check it out
till I banged on the relay, then it went back up to 180 once the fans shut off.
Lots of luck,
Tony
Tony
JRust
May 9 2009, 01:31 AM
I think it is probably just air. I kind of gave up on it earlier tonight. It had pissed me off enough for the week. I'll try a few of the suggestions tommorow. I'll get water flowing thru everything tommorow or use gas & torch the muther phuker. Just kidding! I'll get it worked out eventually. Probably better I don't have a pro here with me. This way I will definately know & remember how to do it next time. It's all good just got a little pissy with it earlier. I'll get an update tommorow when the fire dept comes
Bruce Hinds
May 9 2009, 09:59 AM
I agree with all the Trapped air discussion. Specifically, the hoses from the water pump to the block if you have the remote located pump are notorious for trapping air.
The thermostat hole too, for the chevy they make a high flow version that has holes around the flange. I found this to work really well. Seems with the long run of narrow hoses you get lots of temp changes during different driving conditions and the HF stat seems to dampen those changes.
Also if you disconned the system again... just make sure the pump is pushing water. At one point over the years I had an impeller failure, I think it was spinning on the shaft and would only push water while not under pressure.
B
JRust
May 9 2009, 10:30 AM
Okay so I discinnected the top hose on my radiator. The connected my garden hose to the top hose. Then I turned on my hose & just let the water flow thru my system. It only took a second for water to come out of the top of my radiator. I let the water just flow thru my system for a bit. I was outside & the water coming out was no problem. I fill both the radiator & hose as full as they will go & reconnect them. Then I proceed to start burping again. I let it run for a minute, shut it off, open the top petcock on the radiator & just get air coming out. I close it & do it again. Same result. Then I notice some water leaking by my water pump. I figure a hose is loose. Nope I managed to cross thread one of my bolts on the thermostat cap going to the motor. So it wasn't tight & the phucker broke (the bolt)when I went to take it out
It was a little tough going in but not bad. Came out a little tough originally so I wasn't to worried
At least it's sunny outside. Nice day for a ride into the auto parts store
I'm batting a 1000 so far.
drive-ability
May 9 2009, 05:42 PM
JRust
May 9 2009, 06:36 PM
Okay so in order to drill out the bolt I pulled my manifold completely. The way my distributor sits & trying to do it in the car just didn't work. The upside was I can see some of my water flow problems. The front port on both sides of the manifold were close to blocked with all the silicone they used when they put it on. So that was the bright spot in needing to pull the manifold. I've got it all back together without a thermostat for know. I do plan to put a t-stat in but I'm going to eliminate that as a problem for now.
The down side is I pulled my distributor & although I am sure I got it back in right. I disconnected all my plug wires too. I should have marked them as they don't match what my manifold says. Feels like I am off on my order. Not a huge deal & I can actually figure that one out. Just taking a break right now. I'll screw with my timing tommorow.
I also got my rear caliper rebuilt today & am going to put it back in tonight. Then bleed my brakes. I am making progress & feel good about being ready for WCR. Once I got over my initial pissiness with my cooling woes. Once I am done I should have the cooling on my car down pat
Todd Enlund
May 9 2009, 07:29 PM
Go, Jamie Go!
Man, it's getting down to the wire...
TC 914-8
May 9 2009, 10:59 PM
Whoa Man, It's deja' vu all over again, Not to bring back bad memories.
Good luck, be patient, and drive it for a couple of days before heading south.
Put in a good word for me at the WCR So Cal.
JRust
May 9 2009, 11:44 PM
Done deal Tony. Sorry we won't be seeing you there. I doubt I am going to have alot of seat time before we leave. Still I should manage a good day or 2. Barring me screwing something else up that is
marks914
May 10 2009, 04:29 AM
Once you get everything back together:
Do you have an overflow tank? This self-burps the system (see image)
I was having some cavitation issues, the car would get hot, I would turn on the heater, making coolant flow through the heater core, and the temp would immediately drop. I would then turn off the heater and everything would be fine.
What I did to eliminate the caviitation and/or air in the system from getting caught in my water pump is install a coolant crossover. I have a 3/8 inch line going from my heater outlet on the block back to the inlet on the water pump. You will notice that the block on the SBC has a provision for this on the water pump atachments. (the hose adapters on the front of the blck has one long extension covering the hole on the pass side below the fitting). This weep hole allows coolant to continuously flow through the pump, preventing cavitation and air from getting stuck in there, keeping coolant moving.
Mark
andys
May 10 2009, 11:00 AM
I found that on my Ford Explorer that I will never get the coolant to flow (after re-filling) without pulling off the heater hose at its highest connection point to allow the air to purge out. Without doing that, there's no hope of getting the coolant to flow.
Let's see some of those photos; with all the V8 folks here I'm sure we can get you through this.
Andys
Dr. Roger
May 10 2009, 11:21 AM
i'm with andy's on this one.
i had a similar experience with my V8 setup.
did you say you have a renegade water pump? meaning a pump running off a pulley at crankshaft level? or a remote like mine?
the height makes a difference in burping procedure IMHO.
JRust
May 10 2009, 01:07 PM
Here are a few pics. Just a stock mechanical pump. I wanted to go to a remote as the stock one sticks out so far. I'm actually more worried about getting my firing order & timing figured out today. I think I've got the burping procedure down pretty good now. I didn't get to bleeding my brakes last night so I am doing that in a minute. I went & bought timing light as I didn't have one. Yeah back to the garage I go
charliew
May 10 2009, 01:27 PM
You are the mech. but I always tried to avoid making a job harder than it needed to be. I don't see that the dist. removal is needed to get the manifold out but anyway. Check the rotor direction as that determines the way the wires go on the cap. Surely you didn't turn the motor over with the dist out. If the dist went back in all the way down it should still be in time. Just go by the firing sequence and put the wires back on the cap. Next time you need to remove the dist. leave at least one side of the motor wires on and it will be a lot easier. From the picture it looks like there is no firewall in the car.
drive-ability
May 10 2009, 01:36 PM
QUOTE(JRust @ May 10 2009, 12:07 PM)
Oh Boy !
A factory pump humm
From the web the firing order is the same as the small block chev.
18436572
JRust
May 10 2009, 10:03 PM
QUOTE(charliew @ May 10 2009, 12:27 PM)
Pulled the distibutor to try to drill the bolt in the car. Still couldn't get a good straight shot & so pulled the manifold then. Took me a little while to get the distributor back in right. Didn't want to go down all the way. Yeah I know there is a slot it needs to line up just right with (now anyway). I did say I'm not a much of a mechanic
. Still learning more each day. Yes the firewall has a fairly large section cut out. Not my doing but how I bought it. It will be going back into place sometime this summer. I've got top dead center on #1 & my firing order. All plug wires back on & in the right spot. Timing still a little off but I'll figure it out tommorow.
I did get my brakes all done & bled. Also got my new Tarret drop links put on the front. Just need to get my timing right tommorow night. Then get to cleaning & shining her up
Dr. Roger
May 10 2009, 10:33 PM
the pic explains a lot.
you'll never get air outta' there, unless you place an air trap hose and cap at the highest point in your cooling system.
in your case it is that big hose that arches (the high point) to the thermostat housing. and your little hose going to the intake manifold.
have you considered rerouting both so they won't trap air?
computers4kids
May 11 2009, 07:52 AM
QUOTE(Dr. Roger @ May 10 2009, 09:33 PM)
Jamie, Dr. Roger has an excellent observation. I know you said you had a fill point but I can't see it in your picture. It needs to be mounted so it is higher than any other point of water routing on your engine. Here's a few samples of different methods. Go get a $6 overflow kit at the FLAPS and move your fill point appropriately and get those high rising loops out of your design.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
boxstr
May 11 2009, 11:39 AM
Jamie, Make sure the tires on the trailer are in good condition.
CCLINHWY101
Phoenix-MN
May 11 2009, 12:11 PM
The Buick timing cover is the same for the V6 and V8. I created a high pont to fill from and to easily change the thermostat by modifying a Fiero L4 filler neck (circled in red) This is now the highest point in the cooling system.
Click to view attachmentPaul
JRust
May 11 2009, 01:55 PM
QUOTE(boxstr @ May 11 2009, 10:39 AM)
CCLINHWY101
My trailer is brand spanking new & so are the tires. I also have 2 spares just to be sure. Smart ass with the good memory
. Looking forward to leaving thursday morning.
JRust
May 11 2009, 01:57 PM
QUOTE(computers4kids @ May 11 2009, 06:52 AM)
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentMy fill point is higher but hidden n the left. It is run off a tee in the line down low. Guess that isn't the way to go. I'll go get an overflow kit & get it done right. Thanks for all the great advice people
. Getting closer everyday
boxstr
May 11 2009, 06:08 PM
Jamie If you are ready in time, get some seat time in the V8 car. You will find out closer to hoem if you are going to have any issues before hauling it all the way to LA.
Jsut a thought.
CCLINICOULDHAVEAV8
fiid
May 11 2009, 06:52 PM
I have a subaru motor; I have to say - burping a water cooled 914 is a total pain in the ass. I have a valve outlet on the top of my radiator that I use, and it still requires a lot of nursing to get the thing filled up and cooling properly. usually I connect a funnel to the radiator (via a tube) and squeeze the hoses to get the air bubbles to come out the burp valve, and then close the valve while there's still water sitting on top of it.
I think the real problem is that the hoses are low across the middle of the car; so you can't get the air from the front to return to the rear, because it will just sit up in the radiator, and the pumped water will trickle past it.
JRust
May 11 2009, 08:49 PM
QUOTE(boxstr @ May 11 2009, 05:08 PM)
Jsut a thought.
CCLINICOULDHAVEAV8
I plan to Craig. Wednesday I will spend most the day driving & spit shining it after that. Still this is a big reason I am taking a trailer. Better safe than sorry. I have experince with both
Bruce Hinds
May 11 2009, 11:29 PM
[/quote]
That is a major part of the problem, air will always go to the highest point and needs to get out. I used a regular radiator so it has a cap. I run my overflow hose to the back and "T" into the over flow tank with the other hose off rear fill. Just to complicate matters I have another high point. I installed a heater core in the fresh airbox for winter heat.
LvSteveH
May 12 2009, 04:50 PM
The Renegade radiators have a bleed valve at the top to remove any air that accumulates up front. A well designed system should be able to be bled from several points to minimize trapped air.
I've had a few cars over the years that were extra hard to bleed for one reason or another. If all else fails you can put in some extra air bleeds and do the floor jack mambo. Basically just alternate lifting the car as high as possible at various angles to encourage the air to migrate to an available bleed site. Kind of like herding cats.
It's really nice to have a filler neck up high with a reservoir to collect any air that accumulates. That helps keep the air from moving through the system.
JRust
May 13 2009, 02:28 PM
Okay so I have my car all timed & running well. Drove it for a good 2 hours today. Tried to do alot of it in town as that is where it heated up before. Not the best conditions here with it raining & about 55 degrees. I don't have a tstat in it at this point & am not putting one in for WCR. I couldn't hardly get my car to warm up. I hit a whopping 170 & couldn't get it go above that. It will be nice to see what some nice CA hot weather will do.
As things stand now. [b]I am ready to load up for WCR[b]
pjhaun
May 22 2009, 07:41 AM
Jamie,
What ever happen with your cooling problem?
Thank You!!!!!
Phillip J. Haun
Oak Harbor, WA.
