QUOTE(Vacca Rabite @ May 27 2009, 01:26 PM)
QUOTE(mskala @ May 27 2009, 11:58 AM)
If they are not meant to adjust, please explain the purpose of all the parts
inside other than the screw and locknut and why they are not directly connected
to the piston.
Read this, and find out.
Eric's Rear Brake Venting PostZach
Okay, first of all, right in that thread, The Cap'n specifically states he's never
had to re-set the venting clearance between pad changes.
Second of all, if they were not designed to be self-adjusting, is there a spot in
the Owner's Manual that says to adjust rear venting clearance as part of
periodic maintenance and not just when putting in new pads?
Not that I'm saying they all work, or the design works well, but I believe that
every time the brakes are applied there is small force that is supposed to
make the mechanism move outward by rotating on the screw. But it's been
many years since I've had the parts out.
