QUOTE(Bartlett 914 @ Jun 20 2009, 10:41 AM)
How is the passenger side? On the under side there is a reinforcement strip that also may need replacing. Both AA and restoration design have floor sections and the prices are pretty reasonable. This works better than using old metal.
The passenger side is perfect. The drivers side had a problem as it looks like the previous owner hit a rock or something that scrapped down the drivers side but looks like it tumbled right under the seat where the rust is and took out some of the under coating. Other than this section, its pretty rust free.
What size sheet of steel would you use? 16 gauge? 22 gauge? If possible would you keep it one sheet? Will Rustoleum paint, after its fixed, keep the rust under control?
Thanks everyone.
Eric
