Full Version: TIP: Embedding YouTube videos
Pages: 1, 2, 3
ellisor3
So for us dummies
1.) Click Code
2.) Inside the brackets, change code to youtube
3.) paste the youtube name
4.) Click Code again
5.) Inside the brackets change code to /youtube
Done
VaccaRabite
QUOTE(ellisor3 @ May 2 2011, 01:45 PM) *
So for us dummies
1.) Click Code
Done
I think it is faster to just type out
CODE
[youtube]paste the youtube name[/youtube]
Less steps, and you can do it from the "quick reply" window.
Zach
QUOTE(Vacca Rabite @ May 2 2011, 02:19 PM) *
CODE
FlatSix
https://www.youtube.com/watch?v=uCmqITLZSrM
okieflyr
Testing the embedding thing..
<! :stromberg: ! width="560" height="345" src="http://www.youtube.com/embed/C6b54bZepoA" frameborder="0" allowfullscreen></! :stromberg: !>
QUOTE(okieflyr @ Sep 6 2011, 07:31 PM) *
<! stromberg.gif ! width="560" height="345" src="http://www.youtube.com/embed/C6b54bZepoA" frameborder="0" allowfullscreen></! stromberg.gif !>
As explained three post up:
Type:
CODE
[youtube]C6b54bZepoA[/youtube]
to get:
https://www.youtube.com/watch?v=C6b54bZepoA
Eric_Shea
https://www.youtube.com/watch?v=gCwX57zoMCc
okieflyr
Well since my behind the scene test became the example, I did try the shortlink first but that didn't work either. This long url I just used was supposed to be the embed link?
Andy, your example shows the pink code bar, is that what I should be looking for?
Eric_Shea
My guess is you didn't grab all of the code in the short link the first time.
-> C6b54bZepoA <-
okieflyr
One last try tonight. (Nevermind it will have to be on a different machine).
QUOTE(okieflyr @ Sep 6 2011, 07:45 PM) *
The "code" in pink is needed to show you what you need to type. I have to wrap it in a "code" block because otherwise what i type would show the actual video and not what you need to type.
ONLY type the words in the white section of the "code" block. You start by typing the word youtube with the brackets around, then you type the youtube video identifier C6b54bZepoA the you type the word youtube with the brackets around but precede youtube with a forward slash.
Just like shown in the white portion of the "code" example below. It's really as easy as just typing this out:
CODE
phillstek
(b)lHq9s1Sw7xA(b)
phillstek
https://www.youtube.com/watch?v=lHq9s1Sw7xA
QUOTE(phillstek @ Nov 10 2011, 02:30 PM) *
(b)lHq9s1Sw7xA(b)
phillstek
QUOTE(SirAndy @ Nov 11 2011, 09:33 AM) *
(b)lHq9s1Sw7xA(b)
I'll try again
Jeffs9146
https://www.youtube.com/watch?v=ZmVYNV01K-U
See if this works
McMark
I think you're missing a letter
QUOTE(McMark @ Nov 10 2011, 06:31 PM) *
Youtube tells me that
lHq9s1Sw7xA
is not a valid video tag ...
Jeffs9146
McMark
It's a bit tricky. Nice work!
Mark Henry
I do seem to have problems when the code ends with "=related" (or ends with = anything), I've tried doing it with and without the "=related" ending and still have problems.
What am I doing wrong in this case?
Example:
(youtube)XYZ(/youtube) no problem
(youtube)XYZ=related(/youtube) problem
QUOTE(Mark Henry @ Nov 11 2011, 06:09 AM) *
Example:
Embedding youtube videos here only works with the youtube ID tag. You can't add any additional parameters, like "related". That won't work. You need to strip off anything that is not part of the actual ID tag.
phillstek
rick 918-S
Trying Google videos
http://video.google.com/videoplay?docid=-344275451296655274#
[google]344275451296655274#[/google]
McMark
rick 918-S
QUOTE(McMark @ Apr 24 2012, 04:21 PM) *
jsayre914
o.k. im struggling.
youtube is not what it used to be. Now i cant get it to work....
what do i type to make this one work????
http://www.youtube.com/watch?feature=endsc...YZT_B0&NR=1
carr914
I have a bit part in this Video & I have all the Important Helmets
https://www.youtube.com/watch?v=C_goFIeOWPw
QUOTE(carr914 @ Dec 17 2012, 04:21 PM) *
Let me try
(youtube)<! stromberg.gif ! width="420" height="315" src="http://www.youtube.com/embed/C_goFIeOWPw?rel=0" frameborder="0" allowfullscreen></! stromberg.gif !>(youtube)
Nope, like this (without any of the other crap, just the video ID inside opening and closing youtube brackets:
CODE
[youtube]C_goFIeOWPw[/youtube]
jsayre914
QUOTE(jsayre914 @ Dec 17 2012, 06:59 PM) *
o.k. im struggling.
what part of this vide is the id tag, im good at doin this, but i cant find the i.d. on this one
i tried every combo
carr914
https://www.youtube.com/watch?v=BzTRTQkmHpU
QUOTE(jsayre914 @ Dec 17 2012, 04:25 PM) *
o.k. im struggling.
i tried every combo
HTML parameters are always key=value pairs that are delimited by & ...
In your case "feature=endscreen&v=P7cm7YZT_B0&NR=1" is three key=value pairs:
feature=endscreen
v=P7cm7YZT_B0
NR=1
The video ID is the value for the 'v' key:
Your video ID = P7cm7YZT_B0
Put that into opening and closing youtube tags:
CODE
[youtube]P7cm7YZT_B0[/youtube]
and voila!
https://www.youtube.com/watch?v=P7cm7YZT_B0
theleschyouknow
test
https://www.youtube.com/watch?v=89dq4wvhxPg
Harpo
https://www.youtube.com/watch?v=bgsZmjkPCM0
bgsZmjkPCM0
McMark
Copy and paste this:
CODE
[youtube]bgsZmjkPCM0[/youtube]
tygaboy
https://www.youtube.com/watch?v=HprL5s4Cgjo
Krieger
https://www.youtube.com/watch?v=S_xFuWmdhLk
test
TINKERGINEERING
https://www.youtube.com/watch?v=lfGKeQZNsKQ
MM1
https://www.youtube.com/watch?v=rNor06VRwJQ
Active ailerons
theer
Test
https://www.youtube.com/watch?v=ZWlMSorfyuE
sb914
https://m.youtube.com/watch?v=RkMMj0Ln32s
Test: oops I still can’t figure out how to post videos.
QUOTE(sb914 @ Jan 26 2022, 07:26 AM) *
@sb914
How about you start by reading the instructions in the first post in this thread?
You didn't even try, you just copy&pasted a link to the video ...
All you need to do is type this in your post (without the CODE part, which is just a fancy title for a section that prints code without interpreting it):
CODE
[youtube]RkMMj0Ln32s[/youtube]
Which will show up like this once posted:
https://www.youtube.com/watch?v=RkMMj0Ln32s
ClayPerrine
QUOTE(sb914 @ Jan 26 2022, 09:26 AM) *
Use this website to generate the required code:
https://www.tools4noobs.com/online_tools/youtube_xhtml/
Then enable HTML in your post. Either version works.
Clay
jkb081
QUOTE(iamchappy @ Jun 25 2009, 09:57 PM) *
Well then I guess this confirms what I’ve suspected all along. I’m in idiot!! Lol! I can’t even figure out how to post pictures to my posts on this forum/site. I have gone over the instructions many times…and nothing! I have asked for clarification, no reply. So I give up.oh well…
barnfind9141972
Victory! Fast forward for Jeff Zwart celebratory donuts!
https://www.youtube.com/watch?v= 0WFXKKYpQHQ
Van B
I don’t see any of the embeds here or the one I tried on my recent thread, what gives? confused24.gif
FWIW, I’m using an iPad and I’m wondering if that is the problem?
iankarr
Could be. The latest version of Safari won't let me call for a video here. I have to use Chrome. The syntax is simple when you're on a compatible browser. See @sirandy s post #92
Van B
QUOTE(iankarr @ Mar 21 2022, 03:45 AM) *
Definitely an ipad issue. I was even using chrome on the ipad. I'm logged in from work this morning and I can see all the videos.
I guess on the upside, at least I was linking correctly.
Thanks Ian!
MM1
Just reviewing the technique:
https://www.youtube.com/watch?v=uCijN4KRtec
rhodyguy
iPad? Seems impossible. Posting? Go to different room, turn on computer, wait, learn how to cut and past, fail a few times, hassle. No.
