Full Version: 356SC 2.0L in my 914
Nor.Cal.914
My current 1.8 Type IV in my 914 is in need of a rebuild and I want to get it out of the car fast. I just received a freshly rebuilt 2.0L from a 356SC (Type I ??)for free this weekend and I am planning on putting it into my 914 as a temporary fix until I can fully rebuild my 1.8. I'm posting here with a few questions:
1. Do I have to use the 356 flywheel and clutch assembly or is there a way to run the flywheel and clutch assembly from the 914? The flywheel looks like it is held on by a single center nut on the 356 engine so I assume Type IV flywheels will not bolt up to this engine?
2. Is there a difference between a flywheel for a 6V system vs. a 12V system? Are there more or less teeth on the ring gear for a 6V system compared to a 12V? I only question this because maybe there are more teeth on a 6V system to be able to spin the engine faster?
And finally, is there anything else I should know that has to be done to make this engine work? Like I said, this is only a temporary fix until I can fully rebuild my 1.8L Type IV so I would just like some help on finding out what I need to know to make this engine work. Thanks!
-Chris
Also, I was told that the 901 will bolt up to a 356 engine so I am hoping that means there is a way to make this all work!
markb
I would think you could put the 356SC motor on the Samba for sale, and take the money & buy another engine for the 914. I think there are more problems getting that motor in the 914 than it's worth, and those 356 guys love finding those motors.
Nor.Cal.914
QUOTE(markb @ Jul 8 2009, 06:34 PM) *
If it does turn out to be too much trouble I might end up doing that, but I would like to find out everything involved first before deciding on whether or not I want to do that. I think it would be pretty fun to try and make it work, but we'll see. Thanks
-Chris
Jake Raby
I hope this is a joke.... I really, really do.
Nor.Cal.914
QUOTE(Jake Raby @ Jul 8 2009, 07:10 PM) *
That is why I didn't want to post here with this, but I thought people would be decent enough to at least answer my questions. I didn't post this to find out what people think, I just want a couple questions answered if it's not too much to ask. I know people here are extremely knowledgeable and I like posting here with questions knowing that you guys always come through with a helpful answer! Thanks
-Chris
Cap'n Krusty
You want answers? Here goes. A 356 engine is 80-100 HP 1.6L, not 2.0L. It's also not a Type 1. HUGE difference! Common big bore applications bring it up to like 1720ccs. The engines are fragile, and broken cranks are not uncommon. A proper rebuild with good (but not "top") quality parts and labor can EASILY top $10K. Going first rate can be $14-15K. To accommodate coupling one to a 914 transaxle requires a 912 flywheel and clutch. Flywheels are a dime a dozen, relatively speaking, as a great many 912 engines have either gone into 356s or gone to engine heaven. 912 clutches have gotten uncomfortably pricey.
6 volt starter ring gears are smaller in diameter than 12 volt ones, and have fewer teeth. A 12v ring gear installed on a flywheel and fitted to a 356 transmission will interfere with the bell housing.
As far as making it work in a 914, you'll need a 12v generator and regulator. As the small diameter 12v generators are nearly NLA in any form, you'll need a generator stand for the larger generator ('68-'69 912) and the associated generator tin. You'll need to figure out a way to attach a home fabricated motor mount to the front of the engine, and there is no place on the case to fasten it. That means you'll need to fit and pin a 912 front cover to the engine. Doable, IF you know what you're doing. THEN you have to build the mount. Finally, you'll have to fabricate an engine compartment air seal between the engine and the body. Any air going up or down around the engine is not good, and will contribute to overheating. You'll have to fabricate an exhaust system from scratch, because there aren't any out there that I've ever heard of.
This all assumes the fan shroud will even clear the engine lid and/or the rain tray.
All this stuff applies to a T1 engine, EXCEPT, you'll have to buy a custom made T1/T4 adapter flywheel and a special clutch. A 2L T1 engine is apt to be AT LEAST as fragile as a 356/912 engine, BTW.
There you go, everything you wanted to know, most of which you didn't really want to know .................... The Cap'n
r_towle
A running unknown (rebuilt by an amateur) 356 motor would be considered a core motor, or at the very least a spare motor.
First, post a few good pictures of the motor and the serial number of the motor so we can tell you if its a 356 motor or a 912 motor.
There will be a significant price difference on the used market.
912 motors are considered spares.
Real 356 motors with the correct numbers on the case, and the third piece can bring decent money
Older 356 motors can bring real money...even used.
A used 912 motor might pull 2-3k
A used 356 motor might get you 5k...more if you find the guy who owns the car that matches that motor...or a car that is the right year...and he needs a motor.
Older motors, rare motors bring more...
Sell the motor on the 356 registry, NOT the samba.
If you want quick cash...PM me. I might be able to get it off your hands locally FAST.
If you want some more details, post pics.
You could sell the motor for the right price and buy a decent motor to work in your car....and save alot of head scratching.
Rich
davep
QUOTE(Nor.Cal.914 @ Jul 8 2009, 04:45 PM) *
I think the lack of respect you got was because of the lack of research you did to start with. First off, a 356SC engine is far from a type 1 motor; yes they both are flat fours, but that is about it. A freshly rebuilt 356SC motor is about $20K, and no one gives them away free. A 356SC motor is 1600cc, not 2.0L; the only 356C motor of 2.0L displacement is a Carrera motor worth upwards of $100K, again not given away free. So to start with, what kind of an engine have you really got?
Considering what the Krusty one says, trade the free engine for any type 4 motor you can find.
type47
I hope I didn't read this too fast to see if this had been mentioned. The above information is coming from some experts and they are really trying to help, however they appear to have replied. The problem I see with your situation is the exhaust system. Type IV motors have the exhaust come out the underside of the engine, basically, the exhaust exits toward the ground. A 356, and a Type I also to my knowledge, exits the exhaust out of the ends of the heads in a horizontal to the ground direction. That means, if you install the 356 motor, you have to custom fabricate an exhaust and to me, that would exceed the cost of a Type IV rebuild. My recommendation: verify that it is indeed a 356 and not a VW type I motor, then sell it and use the money to rebuild the type IV. I've seen 2.0L type IV's for sale here for $1000 for a plug-and-play motor.
ME733
Yes agree.gif agree.gif agree.gif and If the 356 engine is actually a 356 SC.(confermation by crankcase,timing case numbers).its one of the most VALUABLE of all the 356 engines made....Therefore...selling the engine...will produce FUNDS/cashorama/moola/MONEY!!!!...of sufficient quantity to let you afford a very good,nicely built 914 engine and all the accessories it may need, exhaust, muffler,etc,etc..you may even have enough money left over to buy everyone here a beerchug.gif .certainly enought to congratulate yourself on how SMART YOU WERE!. bye1.gif
Joe Bob
If you think it's harsh here....try asking about a Type IV engine in a 356 on the 356 Registry. Yer ass will have blisters....
r_towle
QUOTE(mikez @ Jul 9 2009, 12:07 PM) *
What...are we bored...
Lets go have some fun...
I have this old bent window cabriolet I have been thinking about putting a mid engine chevy motor in it...
How would you go about cutting the frame to fit the motor??
Rich
Cap'n Krusty
QUOTE(r_towle @ Jul 9 2009, 05:54 PM) *
Rich
Plasma cutter, definitely. Sawzall's too unmanageable for such delicate work.
The Cap'n
sww914
I don't think you need to cut, Rich. I think you can get it in by just heating with a rose bud and a big sledge to move the metal out of the way.
It worked on the firewall of my S-10 when I put a SBC in it.
After that, a bit of undercoating and you'll be there.
Man, I wish I still had that truck.
Nor.Cal.914
QUOTE(Cap'n Krusty @ Jul 8 2009, 07:56 PM) *
Well that about sums up my options then sad.gif I appreciate you taking the time to tell me all of this though, that is extremely helpful info! How much do 912 flywheel/clutch/pressure plate assemblies run for? I'm sure it's more than it's worth, but I'm still curious to know. Thanks
-Chris
URY914
Nor.Cal.914
QUOTE(r_towle @ Jul 8 2009, 08:06 PM) *
Rich
I see... Well I did some more researching of myself and discovered my initial post was way wrong. The motor is a 356C 1.6L from a 1965. It was taken apart and just "refreshed" rather than rebuilt. The engine was put together by my grandfather who has been working on Porsche engines for over 20 years so I believe he is a little bit better than an amateur engine builder biggrin.gif I might be selling the motor, but again I'm going to go over my options first before I make my final decision. Also, I will post pictures in the next couple hours. Thanks
-Chris
Nor.Cal.914
QUOTE(davep @ Jul 8 2009, 08:29 PM) *
The lack of research was due to the fact that I was handed the motor this weekend and I was just too excited to want to look anything up, but rather go on what I thought would be necessary along with asking some questions on this forum. And the engine was given to me by my grandfather who had a 356C that he sold a couple years back so that was the only reason I got it for free. Thanks
-Chris
Nor.Cal.914
QUOTE(type47 @ Jul 8 2009, 08:37 PM) *
I figured I might have to have exhaust custom fabricated but I also (possibly stupidly) thought I could maybe just switch sides and make the J-tubes point their opposite directions. Not sure that it would work, but again it was just a "quick-fix" thought I had come up with. Thanks
-Chris
Nor.Cal.914
QUOTE(mikez @ Jul 9 2009, 09:07 AM) *
It's not really "harsh," I just knew that I wouldn't get the nicest response when I decided to post this. But again, I was looking for a quick fix that I didn't know anything about and I came here with questions knowing that you guys would supply me with the responses I needed. Thanks
-Chris
r_towle
ok...
The sold car...if that motor is the correct serial numbered motor for the car that your grandfather sold...that person will pay THE MOST for the motor.
No offense to your grandfather, but if he is not well known in the 356 world...the motor wont be trusted...though I am sure he did a great job..its just the nature of the group.
Most of the real buyers are 60 plus years old...so dont be surprised if they know your grandfather and the car...
These motors did go into mid engined cars, so the exhaust could be done as you say.
I bolted one up to a 914 tranny (used a 912 flywheel) all of that worked fine.
You will need a 12VDC generator and stand...I think that would be the most expensive piece.
The exhaust is just tubes...it can be done.
I would share more data about the motor...then sell it.
You can get a decent bolt in motor for your car for a few thousand....
Rich
Rand
There's no excuse for lack of respect. Lack of research? What better place to research questions like this than here? It's a forum, and it was on topic! Damn, there's been a couple bummer attitudes around here lately. Sucks that it has made some people afraid to post questions. Questions are what keeps this place alive.
Nor.Cal.914
QUOTE(r_towle @ Jul 9 2009, 07:52 PM) *
ok...
Rich
How do you find out who owns the car that this engine came out of? And where is that "356 registry" that was mentioned earlier? I would really like to find the person who owns that car now and try and return this engine to its rightful place! How did you make the tin fit in the engine bay without allowing air to flow up past it? I was just looking around on craigslist for some miscellaneous parts and found a 12V generator for 125 bucks (may need a rebuild but I know a place that will do it for less than 100 bucks) so depending on how much a 912 flywheel is maybe this won't be all that expensive to mock up? Does the 912 use the same clutch disc and pressure plate as a 356 or a 914 or is it completely different? Please let me know. Thanks
-Chris
Nor.Cal.914
QUOTE(Rand @ Jul 9 2009, 09:37 PM) *
agree.gif I came here with questions knowing people here would be more than helpful in answering them! Maybe it IS a waste of time in some peoples' opinion, but I am a fan of working with difficult projects and making them work! I posted only asking for a few questions answered, not to have my questions put down just because of lack of interest from others. I don't want a bad reputation here; there are way too many good people and helpful members here that I would hate to be looked down upon by you guys! I appreciate all the helpful answers everyone has given me so far and I only hope the rest will be just the same! Thanks
-Chris
Cap'n Krusty
ok...
Rich
"These motors did go into mid engined cars, so the exhaust could be done as you say." Oh, really? Not that I've ever seen or heard of, and I've been around Porsches since 1963. Actually, there was one. Platypus, a limited production race car from San Diego in the 50s. The Cap'n
Dave_Darling
Don't forget the first couple of 550s had plain-bearing--and therefore basically 356--engines, at least for a few races.
--DD
Rav914
QUOTE(Nor.Cal.914 @ Jul 9 2009, 10:23 PM) *
-Chris
Don't be discouraged. I think everyone here has your best interests in mind. They want you to come out ahead fiscally and mechanically.
You want a fun project? Build a Type IV 1911 motor. Hands down faster than any stock 616 (356/912) motor I've owned.
Nor.Cal.914
QUOTE(Rav914 @ Jul 9 2009, 11:28 PM) *
Thanks Rav914, I know everyone is here to help and that's why I love coming around here so much! I was planning on building my 1.8 into a 2056 after I found a replacement motor to put in until I could finish the rebuild. I already have a set of 96mm p&c's waiting to go in, I just need some more parts before I can actually take the engine out and rebuild it. Thanks
-Chris
Joe Bob
I think what really twisted the 356 crowd's panties is when I put a six in one....then cut the roof off, tube framed it to keep it from bending in the middle, put in a boom box with a HUGE bass speaker, flared the fenders and did burn outs in the GAF parking lot.....it's the little things that make life fun...
http://www.356registry.com/forum/
Click on the link above for the crotchety old bastard's club....
davep
underthetire
If you just need a temporary engine....I've got a bus 1.7 you could use till you get yours built. Just make the hour drive and pick it up.
scotty b
QUOTE(Nor.Cal.914 @ Jul 9 2009, 06:24 PM) *
-Chris
He who look for quick fix usually end up broke.
Nor.Cal.914
QUOTE(underthetire @ Jul 10 2009, 08:53 AM) *
Wow laugh.gif people here are way too nice! I think my 1.8 can make it for a little while longer, but if I feel like it's time to pull it out I will definitely come get this engine! I'm hoping that if I DO sell this 356 engine I can make enough money to buy everything I need for my rebuild and just get it done in a week or so. Thanks for the offer and I will keep in touch!
-Chris
Nor.Cal.914
QUOTE(scotty b @ Jul 10 2009, 12:15 PM) *
-Chris
lol-2.gif I can believe it now after being told everything that has to be done to make this work!
-Chris
Nor.Cal.914
Where do you find the "three pieces" that have the number on them? Someone mentioned that if they have all three matching numbers the engine becomes a bit more valuable? Here are some pics:
Nor.Cal.914
The engine should be up on a stand later today so I can get some better pics. Here's some more:
Joe Bob
Looks in good shape....post an ad over on the Registry....
