QUOTE(SirAndy @ Aug 15 2009, 12:42 PM)
QUOTE(jjbunn @ Aug 15 2009, 10:42 AM)
I'm trying to locate the black/brown wire marked "T1a" on the '74 wiring diagram
It's brown with a black stripe. Originates at your steering column and is in the main bundle going into the front trunk and terminates right around the drivers side fresh air divider box thing.
It may be hidden inside the loom. It was on my car.
http://www.914world.com/bbs2/index.php?showtopic=13261 Andy
OK I have found the wire: it emerged at the place you indicated, and was folded back and taped, hidden, to the wiring bundle.
After extracting it, I checked for +12V when pulling the column stalk towards me: nothing. My car is a '74, but it doesn't have the intermittent wipe option - is that relevant?
I'm a little confused now, as my owner's manual says that the windscreen washers are activated by pulling on this lever, as I am doing. Yet the system in the '74 used the spare tire pressure to eject the water, so how is the column stalk supposed to turn that on and off, and what has it got to do with the brown/black wire?
Sorry, I'm new to 914 wiring
