Since I purchased my conversion 6, I knew it was being starved for power and simply did not run correctly at higher rpms. I checked the timing, valves, and synched the carbs but still ran lean and backfired.
Finally I took it to a guy I know that has worked on teeners for 20+ years and had him take a look. He called back and asked if I was converting my 6 to a VW because it had VW jets in it. To make matters worse, these are Zenith Carbs and the jets are almost impossible to find. I did track back in the PO's receipts and guess who built the carbs, Motor Meister . Apparently they just stuck in whatever would make it run. My questions are:
Does anyone know the correct jetting for a 3.0 with 40mm Zenith Carbs?
Could I assume the jetting is similar to Webbers of the same size?
Does anyone know where I can locate the jets?
Thanks in advance
