Full Version: Diesel conversion - transmission options
type11969
Mulling over a tdi swap into my 914 while I should be working on dynamics HW . . . One big hurdle seems to be the transmission. 914 tranny isn't geared for a diesel and it would be expensive to re-gear it (if even possible). What other options are available? Seems like it would be convenient to use a VAG diesel tranny that was already set up for the tdi engine . . . but most are front engine front wheel drive. Anyone know of any VAG front engine RWD cars using a tdi engine? Old Audi, perhaps? I suppose a diesel Vanagon tranny might work but my guess is the gearing wouldn't be great in that either.
Other options? Linkage I figure I would do with cables.
Thanks,
Chris
johannes
Is this a joke ?
Gary
Pretty healthy discussion here: TDI thread. Looks like pre-B6 passat (longitudinal), O1E audi, or boxster trannys are all possible.
RJMII
I'd do it... 200 hp and 300lbs/ft of torque, and the radiator stays in the engine bay.... and not as much cutting up of the rear trunk.
oh, and 65mpg with that?
rohar
QUOTE(RJMII @ Sep 26 2009, 01:41 PM) *
Hmm, I'm about to put a turbo 2.0 16v vw engine in the teener (engine install is scheduled for winter). The block is similar enough to the TDI block so your comment intrigued me. When I had it mounted in the last chassis, I didn't have to cut any sheet metal in the rear, I did have to fab a couple of water flanges to make that happen, It was close.
How would you mount the radiator in the engine bay? Last time, I put a big old hole in the nose and mounted it up front as everyone does.
Cap'n Krusty
An Audi or Passat diesel tranny would be fine, but you'd need to fab a cable shifter. There haven't been any RWD Audis in decades, if there ever were any. As Vanagons were RWD with the engine in the rear, the tranny turns backwards in a mid-engine application, so that's out.
The Cap'n
type11969
Nope, no joke. I've been intrigued by the tdi engine for a long time. Thought about getting any one of the tdi powered vehicles but I have enough cars already. Figured the 914 needs an engine once I am done and the tdi would definitely be something different.
Thanks for the link, all good info. I'll post over there to see if any progress has been made.
I forgot that Audis/passats were set up longitudinal but still fwd, those would be the trannies I would be looking for. Vanagon definitely wouldn't be that desirable regardless but can't you flip the R&P? I would think that the sandrail guys that run mid-engine setups might do this but maybe they move past the bus trannies at that point.
Thanks,
Chris
VaccaRabite
Why not take the 2056 out of the bug and put the TDI in the bug? That way you could use a Vanagon trans w/o much difficulty.
And it would get the 914 that much closer to being done.
Zach
type11969
Really the tdi should go in the bus but I didn't want the bus off the road for so long.
I'm pretty sure the tdi or any VAG inline 4 won't fit in the Beetle engine compartment without some hacking to the engine lid. But that is a good point I'll look in to. Unfortunately it is only a 1.8 that I have in the Beetle.
I have an engine to put in the 914, a 1.7 that it came with that I would use until I've obtained all the parts for the tdi conversion.
Dr Evil
When you say regearing is expensive, had you considered flipping stock gears to get ratios that are more to your liking? Give me the RPM you want and I can look into it.
type11969
Hmm, no I had not. All good info. I'll have to get back to you on that, this is all in the very basic planning stages. I have a whole lot of 914 to finish first.
Cap'n Krusty
Just a little information about Vanagon trannies in general, and a couple of facts about diesel Vanagon trannies in particular. Vanagon trannies have a REAL problem with the 3-4 gear assembly. They break with irritating regularity. Practically every Vanagon that has been in here over the last 30 years has had at least one tranny replacement, nearly all for the same issue. Now, for the diesel tranny. Since the diesel Vanagons were imported for only 2-3 years (1980/81 to 1983), and the number was limited, where you gonna find one? They couldn't GIVE those things away when they were on the dealer lots.) And since the torque and HP of the original engine was probably half that of the TDI, what makes you think the notoriously weak tranny is gonna hold up under the added strain? BTW, you want to cruise at about 2000-2200 RPM in 5th. That's a 1000+ RPM drop from the stock 914 5th gear.
The Cap'n
Porcharu
Audi Transmission, the older 4 cylinder versions will bolt right up to the TDI. I think some of the newer ones have both the 4 cylinder and the 5/6 cylinder bolt patterns. Cableshift.com has a shifter for this setup.
Steve - wants to put a TDI 5 cylinder into my Oldvo.
Cap'n Krusty
And where do you propose to procure a 4K gearbox with diesel gearing?
The Cap'n
pktzygt
I looked into a diesel swap for my pathfinder. Sounds easy since they sold diesel Nissan p/u in the U.S. and I saw diesel pathfinders all over Panama when I was there last summer.
I never got past the law that "supposedly" says that you can't put a diesel in a vehicle that was not sold with one in the U.S. Then I got my 914 and all but forgot about the idea. Maybe someday I'll find a loophole like putting my pathfinder body on a diesel p/u frame.
Don't ask me to find the law. I heard it from a guy who had done the project and was having trouble getting it registered on NPORA (pathfinder forum) I think. All I'm saying is that there might be legality hurdles in there somewhere.
okieflyr
I would agree with going with an earlier Passat transmission since it is longitudinal. I'm not sure what your going to find to match your diesel though.
A Boxster style shift mechanism can work well with your own custom length cables. OR I still have my leftover low milage Kennedy adapter and clutch/flywheel setup if needed for a 901 conversion.
aircooledtechguy
Ask the guys at Go Westy about this 5-speed box. They may be able to custom gear it for you as well as flop the R&P to work in a 914. . . Worth a call anyway.
Cap'n Krusty
QUOTE(aircooledtechguy @ Sep 28 2009, 06:00 PM) *
Bring money ..................
The Cap'n
QUOTE(type11969 @ Sep 26 2009, 08:43 AM) *
Wouldn't a front engine front wheel drive setup be the same as a mid engine setup besides the location in the car?
You should be able to take that engine and transmission combo and just move it back a few feet.
shades.gif Andy
type11969
Thanks for all the info guys, keep it coming.
When I think of front engine fwd I always think of a transverse layout. I forgot that audis/passats came front engine fwd longitudinal. So it seems like I am looking for a diesel passat (long. engine layout) tranny if such a beast exists. Or look in to gear interchangeability between later transverse diesel trannies and earlier longitudinal gas trannies. Or re-gearing of the 914 tranny, which sounds unlikely with the drop necessary. Hmm.
Thanks,
Chris
bfrymire
QUOTE(type11969 @ Sep 28 2009, 08:04 PM) *
Thanks,
Chris
Not meaning to stir the pot.. Just a thought. Subaru has a new diesel engine out now. If the bolt pattern and engine layout is the same as the EJ25, then there are already parts available to make the swap. You can also get the parts to use the suby tranny. Wouldn't that solve all the problems? (And you might have room to put the radiator into the engine compartment.)
The real hurdle here, is getting one of the new engines.
-- brett
type11969
Yeah, its the "real hurdle" that I am trying to avoid. But, by the time I actually get around to this that might be a viable solution!
-Chris
VaccaRabite
I am so waiting for that engine to be released stateside. That is when I'll likely trade in my daily.
Zach
type11969
Some good intro info over on the tdiforums on the thread I started. To summarize:
It "might" be possible to mount the engine and stock transmission tranversely . . . quick measurement between the nuts on the suspension mounting points reveals 32" of clearance . . . guy online measured one setup he had at 34". Yeah, I know, too big but that is between the crank pulley and edge of the tranny. If I can get the pulley ahead of or behind these points the clearance opens up. Gotta figure out the distance between the crank centerline and tranny output shaft centerline . . . I'm sure the trunk will need to be hacked in this config but I can rotate the engine towards the front of the car to hopefully minimize this. Also, since I will not be using the driveshafts to compensate for the steering angle like in a fwd setup I will have some more flexibility with engine placement relative to the stub axles in the 914. Mating the stubs to the VW driveshafts is another headache though.
Longitudinal tranny options:
The DHY unit has a 3.700 final drive and 1-5 ratios of 3.500, 1.934, 1.300, 0.943, 0.789 B5 passat v6
The DHL unit has a 3.889 final drive and 1-5 ratios of 3.500, 1.934, 1.226, 0.838, 0.683 B5 passat diesel
DQY====3.778=2.118=1.360=1.029=0.755=3.389==Jetta/Golf TDI, for reference
I'm sure it is impossible to find the DHL unit, not sure how tough it is to find the DHY unit, Cap'n? So, just for comparison, at 3000 rpm with a 195/50 r15 tire in fifth gear with a DQY tranny I would be going about 80mph. With a DHY tranny I would be going 70. Could always use a bigger wheel/tire combo too to drop the rpms further. I know this is only part of the picture but cruising rpm is a pretty big part.
So there do seem to be some options to make this work. It will be interesting to see what comes up as I dig deeper.
-Chris
type11969
Potential tranny candidate, seem to be plenty out there:
http://cgi.ebay.com/ebaymotors/98-05-VOLKS...sQ5fAccessories
Same ratios as DHY. Hmmm
type11969
Oh yeah, doc, when you have a minute, how close can you get to the DHY ratios in a 914 tranny? Is there a taller R&P out there?
Thanks,
Chris
Dr Evil
There is a taller diff in certain years of sportomatics. I dont know what the difference is off hand, I need to look it up.
Dr Evil
Actually, I have a sproto diff and pinion that I can hook you up with. It is the set from the sporto that is not the perfect fit for a 901 box, but with a 902 or 912 aluminum plate which is shorter I can make it work I think. It would take some work, but we could do it.
Dr Evil
R&P in a sporto is 7:27 vs 7:31 in stock 901.
type11969
Hmm, interesting, that would result in a taller set of ratios than the passat tranny. Question is, is it going to be more work/$$ to mod a 914 tranny to use the sporto R&P or fab tranny mounts, cable shift, and output shafts to use the b5 tranny. I gotta chat with okieflyer about what he did. I do like the idea of an updated tranny, especially if I can swap in TDI gears at some point.
-Chris
rohar
I don't think I'd let tranny mounts influence your decision. They're pretty simple on the boxster/Audi box conversions and you're going to have to fab motor mounts anyway.
I'd personally be a little nervous attaching a TDI to a 901. That's a whole tone more torque than it came with wink.gif
