Full Version: Shock/Spring recommendation?: 73 914-4
JF914
Saggy rear end....need springs and shocks to boost her back up.
Recommendations please.... car will be used mostly as recreational driver. Perhaps some light Autocross, and a track day (maybe someday)
Specific make for shocks, spring weight, etc and where to purchase?
underthetire
QUOTE(JF914 @ Sep 29 2009, 04:04 PM) *
Saggy rear end....
Millerwelds
I use Bilstiens with 140# springs. Stock front except with Bilstiens there too. Stock front and rear sway bars.
Aggressive street driving. I love it. Not too harsh and it still rips. driving.gif
bfrymire
New or used parts?
Any changes to the car?
Progressive springs in the back with Boge shocks
or
140lb springs with Bilstein shocks. (My pick.)
Front, either stock or one size up from stock.
Used: Watch the classifieds, and you can find good deals.
New: Pelican, GPR, AA, PMB, Elephant Racing, and many more from the vendor forum.
Personally, I like Jonathan at GPR. (www.gprparts.com or click on his banner here)
Also, what about sway bars? Do you have them? Do you have LSD?
-- brett
VaccaRabite
I am using 140 springs in the back, stock sway in front. Shocks are just the KYBs that were on the car when I bought it. Eventually I'll get better ones, but these will do for now.
If you use 140s in the back, I'd not use the rear sway. Could make you tail happy unless you also stiffen up the front end beyond stock.
Zach
siverson
IMO, 140#s is too much for a -4. For a mainly street -4 like you describe, I'd say:
100# rear
Boge (softer) or Bilstein (slightly firmer) shocks/inserts
factory front sway bar
or more aggressive:
100# rear
Bilstein shocks/inserts
22mm (or larger) aftermarket sway bar
And, I've had great luck with Pelicanparts.com...
-Steve
tat2dphreak
I have shortened 100# in the rear with Bilsteins and front is Koni yellows, I got all four shocks from the classifieds at different times, they were still practically new.
jimtab
I have adj KONI struts in the front, and bilstiens with a 120# springs in the rear, and BOTH sway bars hooked up....and it drives fine.....
Chris Pincetich
Ummm, don't bump it up too much higher, it looks kinda normal to me
tat2dphreak
QUOTE(ChrisNPDrider @ Sep 30 2009, 12:36 AM) *
agree.gif maybe the front needs to be lowered a hair, but the rear looks good.
I believe if you lower the front, the back wil actually come up a hair.
blitZ
I would suggest anyone considering suspension upgrades to go with adjustable rear coil overs. It's not expensive and really adds to the potential setup on any car.
