QUOTE(Mark Henry @ Oct 12 2009, 09:10 AM)
Are you deleting the stock cooler? Bad idea... even for most race applications.
A remote cooler in the rear is useless.
Not deleting the stock oil cooler. And running a front oil cooler.
Filter (adapter) MUST be the first thing from the oil pump and close to the engine, as it has the most resistance.
Mount it straight up/down so it doesn't make a mess when you change the filter.
(At first I thought you were saying you are mounting it in the front trunk.)
Oil filter assembly will probably go where the old fuel filter (fuel pump and filter are now in front) went on the passenger side.
Oil lines to the front should have as few turns as possible and a quailty cooler, with good airflow, shound be used.
Planning on running the oil lines up the heater tubes (headers, no heat), and over the front bulkhead into the trunk. I have two boxes of AN-10 braided line. Right now have an Earl's oil cooler, but I'd rather sell it and get one of a different configuration. See me blog for pics of the cooler. Will punch out the grommets in front, and vent to the wheel wells.
That 30mm pump creates a lot of pressure when cold, so your filter, fittings and oil lines better be up to the task. I use Parker Push-loc, no clamps.
Use a steel pump cover and you have to modify the one engine mount on a 914.
I'll be searching for a Schadek 30 mm pump. The Melling that's on there is going in the bin... I looked at the pics of the modified engine mounts, and it looks a lot less difficult than I thought. A little time with the grinder or band saw should do it.
BTW I've built quite a few full flow setups on type 1 and 4 engines.
Thanks for the comments, It's good to know that what I've finally got planned is in the right direction. I'm learning...
-Josh2
