Full Version: Another fuchs thread!
Rod
Sorry guys, I appreciate your help, but I want to be sure that the fuchs I have been offered are right for my narrow bodied 914.
They are 16 x 6 and I have asked for the seller to send me the part numbers, fo r which I have received the following reply...
911 361.020 [43]. And 911 362.113. There are two wheels with the first part number and two wheels with the second part number on them. All the wheels have as10.62 on them. I'm pretty sure the offset is et36
Would these be good for me to spend my $$$ on??
ericread
Rod
sixnotfour
6x16
36 mm
911.362.113.00 (late)
911.361.020.43 (early)
I dont know the diff on the sixes , But on the sevens thearly and late have a different shape triangle window between the spokes.
One being square on the rim side and the other curved .
Get pictures of- each.-
ericread
QUOTE(Rod @ Oct 2 2009, 12:34 PM) *
Sorry Rod... Just kiddin around.
Eric
Rod
QUOTE(ericread @ Oct 2 2009, 08:40 PM) *
Eric
Rod
QUOTE(sixnotfour @ Oct 2 2009, 08:40 PM) *
6x16
36 mm
Thanks for your help - here is a picture of them all
sixnotfour
YEAY Fuchs Thread!!!
Eric
http://www.wheel-whores.com/forum/viewforum.php?f=4
brant
I think Jeff might have mis-read
on the 16's, I don't think there is an earyl/late, heart issue
your good
16 x6's fit well
probably 16x7s would fit with a narrow tire..
but the 6's are really safe
your good to go!
brant
RJMII
QUOTE(brant @ Oct 2 2009, 03:27 PM) *
your good
16 x6's fit well
your good to go!
brant
I'm running 16x7's on all four corners with 205-60's. slight rubbage on the rears because I need stiffer springs and adjustable perches. Cornering hard takes the tire up into the wheel well too far.
RJMII
Rod, if you're getting a good deal, jump on them before someone else does.
Rod
QUOTE(RJMII @ Oct 2 2009, 10:42 PM) *
your good
16 x6's fit well
your good to go!
brant
With all of my Fuching about recently I have come to the conclusion that 50 series tyres are best for a 16" wheel
( I have 60 profiles on my 15" 4 bolts, so a lower profile on the larger wheel should be correct? )
RJMII
Tire diameter = ((((width * aspect ratio)/10)/25.4)x2) + wheel diameter
there's the math. =o)
Rod
QUOTE(RJMII @ Oct 2 2009, 10:43 PM) *
Will do biggrin.gif I'll be back with a conversion thread soon...
RJMII
QUOTE(Rod @ Oct 2 2009, 04:08 PM) *
awesome! Your threads are usually a pretty good read.
sixnotfour
There is a early and late PN and on the 16x7's the base of the heart early curved and late straight.
brant
QUOTE(sixnotfour @ Oct 2 2009, 04:14 PM) *
There is a early and late PN and on the sevens the base of the heart early curved and late straight.
I didn't realize there was an early late in 16inch diameter
I learn something new all the time!
Rod
QUOTE(sixnotfour @ Oct 2 2009, 11:14 PM) *
So what are the differences between the four wheels, bar the part number? pray.gif
sixnotfour
I found some documentation, All mine are early.pre 85 The 7's definately have a different shape heart.
http://forums.pelicanparts.com/porsche-911...variations.html
