Just got the car back from the shop today. It was hesitating between 2800 - 3000rpm's. The needle would jump around a little bit in that area as well. They replaced the points and set the timimg. It runs like a champ now. They also adjusted the valves while they had it.
A few weeks ago I had a hot-start problem. I had a hot-start relay put in. Opinions on this site seem to vary if that is an actual fix or just a band-aid. I thought I would take my chances and just install the relay for now.
I also found some grills without holes to install in the front bumper. Looks MUCH better.
