944 axle to 914 hubs, does it work |
ldscamaross |
Mar 19 2010, 08:30 PM
Newbie Group: Members Posts: 25 Joined: 31-January 08 From: south jordan utah Member No.: 8,646 |
hi does anybody know if this setup works. i have read that people are using the 944 axle and stubs on their cars. does the 944 axle stub, the male end that goes into the trailing arm and hub fit( meaning the same splines and bearing clearances) as on the 914/4 hubs. i know alot of people have used the early 911 hubs but i just want to know if the 944 axle stubs fit the 914/4 hubs thanks
SirAndy |
Mar 19 2010, 08:48 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I run custom axles using 944 parts.
However, you can't use the 944 axle shaft and i didn't use the 944 stub axles either. I ended up machining my 914/4 axle shafts to accept 944 CV joints on both ends which in turn bolted to 911 stub axles and 911 output shafts. I opted for machining the 914 axle shaft as it is the correct length and doesn't require any spacers. http://www.914world.com/bbs2/index.php?showtopic=80641 (IMG:style_emoticons/default/bye1.gif) Andy |
ldscamaross |
Mar 20 2010, 01:14 AM
I run custom axles using 944 parts. However, you can't use the 944 axle shaft and i didn't use the 944 stub axles either. I ended up machining my 914/4 axle shafts to accept 944 CV joints on both ends which in turn bolted to 911 stub axles and 911 output shafts. I opted for machining the 914 axle shaft as it is the correct length and doesn't require any spacers. http://www.914world.com/bbs2/index.php?showtopic=80641 (IMG:style_emoticons/default/bye1.gif) Andy im using bus axles with a subaru tranny. so the 944 stub axles dont fit into the 914/4 rear hubs? |
SirAndy |
Mar 20 2010, 02:06 AM
im using bus axles with a subaru tranny. so the 944 stub axles dont fit into the 914/4 rear hubs? They do fit but they need a spacer otherwise the bearing is not tight and will move in the trailing arm. Do a search here, this has been covered before with pics and dimensions needed for the spacer ... If i recall correctly, the thread for the axle nut is longer too and may stick out too much, depending on your wheels etc. I'm too drunk right now to look it up for you. (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/biggrin.gif) Andy |
PeeGreen 914 |
Mar 20 2010, 07:56 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Andy's setup it a very nice way to go if you can get your hands on the parts. I did this and I love the outcome (IMG:style_emoticons/default/piratenanner.gif)
Attached image(s) |
ldscamaross |
Mar 21 2010, 01:38 AM
cool im glad it works. thanks
Lo-Fi Version | Time is now: 7th June 2024 - 04:51 PM |
