Oh Great Engine Gurus, Help Humble Grasshoppa Understand |
DNHunt |
Jun 20 2004, 05:30 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I'm trying to visualize the Mystery Space. It is located between the Main Seal, the Case and the Flywheel, Endplay Shims and #1 Bearing. It appears to be a sce that catches oil from the main and provides oil for the shims before draining into the case. Is this so?
I mocked it up using some old parts for the picture. The case I want to use is scarred in this area but it appears to me nothing contacts it at this point. The thrust surface for the main is recessed further and toward the centerline of the crank and the seat for the main seal is outboard. Could this be correct? Thanks Dave Attached image(s) |
ejm |
Jun 20 2004, 06:19 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
You are correct, nothing goes there, it's simply a void where you'll find some oil that hasn't returned to the sump.
How did the case get scarred in this area? |
TimT |
Jun 20 2004, 06:20 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE to be a sce that catches oil from the main and provides oil for the shims before draining into the case. Is this so? Yes.... just oil.. nothing else going on in there |
McMark |
Jun 20 2004, 06:42 PM
I bet it got scarred by some genius with a screwdriver removing his rear mail seal. Get the right tool for the job, it's cheap.
Attached image(s) |
DNHunt |
Jun 20 2004, 08:40 PM
Thanks guys for the quick answers. You guys made my day. I don't know how it got scraped up but it goes all 360 degrees around. If the guy was trying to remove a seal, it must have been a nightmare. Anyway, it appears it's gonna work fine.
Thanks Dave |
Lo-Fi Version | Time is now: 8th June 2024 - 06:19 AM |
