Making my own dash, any surfboard shapers help out!! |
TimT |
Aug 11 2004, 07:25 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Im going to make a new dash for my 911, I figure Ill form it out of foam, then vacuum bag some carbon fiber.
Whick foam should I use? which is easiest to shape? I guess Ill use a surform plane to rough it out, sanding it to its final shape, filler as needed Paul the glass guru what do you suggest? Those of you that havemade your own boards any tips? |
jgiroux67 |
Aug 11 2004, 07:36 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
When you do this make sure to take pictures along the way. This sounds like something i might want to do down the line.
URY914 |
Aug 11 2004, 07:40 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,883 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
QUOTE Paul the glass guru what do you suggest Yes, young Grasshopper, listen to the wise 'glass guru. Go to website of expert. There you will find much glass wisdom. Good luck in your jounery...go in peace. Paul http://fgci.com/ |
Mike T |
Aug 11 2004, 07:47 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
I've used stuff I found at A. C. Moore craft store. It's that white crispy stuff used for arts and crafts. You can buy it fairly cheap in big sheets and blocks. They have a contact cement that works pretty good to glue chunks of it together. It cuts real easy with a small keyhole type saw that was right in the same aisle. Sands easy too. The fiberglass resin I used over it didn't eat it but check with a small piece first.
Yes. post pics as you go. Mike T |
URY914 |
Aug 11 2004, 08:03 PM
http://fgci.com/
[QUOTE]LAST-A-FOAM Last-A-Foam® High Density Foam is high strength, high density polyurethane foam for surfboards, stringer replacement and other structural applications. It is used as a core for fiberglass lamination. Nominal sheet size: 2' x 8'. [QUOTE] This is from thier online catalog core material section. You don't need to get it from them but it tells you what to ask for when you go to you FLFS (Friendly Local Fiberglass Supplier). Paul |
Lo-Fi Version | Time is now: 28th May 2024 - 11:32 PM |
