steering wheel removal, horn ring removal, want to pull speedo to fix odo + wrap steering wheel |
potomacmidget |
Jan 14 2012, 11:52 AM
I gotta have more cowbell.... Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States |
Hi All,
My odometer and trip odometer are working intermittently, so I guess I need to pull the gauge and see if I am gutsy enough to disassemble the gauge via the pellican article (or send to a fellow forum member for repair?) To do this I guess I need to pull the steering wheel (first the horn ring). I see in the Haynes manual I am supposed to turn the horn ring CCW, however I don't know if that means an 1/8 of a turn then it pulls off, or does it have to spin multiple times to come off? Don't want to screw up the horn contact wire since my horn actually works. Then wanted to pull the steering wheel to see if I could sew a leather cover on. Any nightmares with pulling the steering wheel? The wheel on my MG Midget comes off very easy but that car is seriously primitive compared to the 914. Any advice appreciated. thanks Reg |
sfrenck |
Jan 14 2012, 01:24 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Horn ring doesn't spin a lot - maybe a 1/8 to 1/4 turn.
I had to "extend" my socket wrench with a piece of pipe to get enough leverage to crack the nut holding the wheel on. |
pilothyer |
Jan 14 2012, 03:16 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Once you turn the horn ring CCW just a little, as stated you will feel it release........Then carefully disconnect the wire from the ring...these will break off if they have been bent too many times......................it can be repaired if it happens but be careful with it. Also don't put the wire through the hole..........I have seen that a lot. Once you have the nut off you may have to wiggle the steering wheel to get it off..........also...be sure to mark the wheel and shaft to get the wheel back on like it came off........that is if it centered properly to begin with....otherwise it will be trial and error till you get it right.
struckn |
Jan 14 2012, 05:51 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
I just pulled my steering wheel today. I'm replacing my ingnition switch.
I used this Pelican Tech Artical fully describs pulling the wheel nicely. The address below is miss leading but it takes you right to it. http://www.pelicanparts.com/techarticles/9...ooler_seals.htm If you want a quick way to cover your steering wheel I bought the universal simulated black leather one at the the Parts Store and then used CY Super glue to glue the seam together all the way around except at the spokes and with out glueing it to the wheel it's self. |
windforfun |
Jan 14 2012, 06:21 PM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Once you turn the horn ring CCW just a little, as stated you will feel it release........Then carefully disconnect the wire from the ring...these will break off if they have been bent too many times......................it can be repaired if it happens but be careful with it. Also don't put the wire through the hole..........I have seen that a lot. Once you have the nut off you may have to wiggle the steering wheel to get it off..........also...be sure to mark the wheel and shaft to get the wheel back on like it came off........that is if it centered properly to begin with....otherwise it will be trial and error till you get it right. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Careful with the wire routing. The design is poor. Don't use the hole. |
windforfun |
Jan 14 2012, 06:27 PM
Heat shrink tube the wire if you need to.
partwerks |
Jan 14 2012, 10:33 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
When my odometer stopped I had just gotten a junk odometer that still had a good long plastic gear in it and put it in mine.
Been a while since I done it, but don't recall it being rocket science. I think you just take a few screws off the back and the housing comes off to gain access and will be self explanatory. |
TheCabinetmaker |
Jan 15 2012, 06:53 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The few screws in the back just hold the innards to the case. The crimped bezel must be carefully un crimped to remove the front. Then unscrew the back and the guts will come out.
potomacmidget |
Jan 16 2012, 07:43 PM
All,
Thanks for all the help I really appreciate it - I managed to disassemble everything with no major issues - thanks for the link to pellican - forgot to check out the tech articles there. Reg |
76-914 |
Jan 16 2012, 07:49 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Reg, if you pop the glass off, be sure to clean the inside of the glass before you close it up. When you see the difference you can do the other 2 gages so that they will match (IMG:style_emoticons/default/happy11.gif) The broken tab is a quick easy fix if that happens.
Lo-Fi Version | Time is now: 8th June 2024 - 12:42 PM |
