911 Coil on Plug Set-up, Custom Valve Covers...914 adaptable? |
Britain Smith |
Oct 9 2004, 12:10 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I found this on the bird board, this guys has a 911 motor with custom valve covers to accept a coil on plug set-up. Brad and I thought about this for my motor, but figure that the Electromotive set-up would be good. What do you think guys...adapable to a type-4 engine with the Kit Carlson FI?
-Britain (IMG:http://forums.pelicanparts.com/uploads3/P10101041097125589.jpg) (IMG:http://forums.pelicanparts.com/uploads3/P10101001097125564.jpg) |
Brad Roberts |
Oct 9 2004, 12:23 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I *thought* the last air cooled engines had COP.
B |
Mike9142.0 |
Oct 9 2004, 01:23 AM
Member Group: Members Posts: 219 Joined: 29-January 03 From: Phoenix, AZ Member No.: 208 Region Association: Southwest Region |
The wet engine was the first for COP in 98.
TimT |
Oct 9 2004, 06:02 AM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
I was going to do coil-on-plug on my 911, I decided against it because machining the valve cover was just another obstacle preventing me from getting the car on the track, so I went with coil packs.
It can be done if your timeframe allow why not try it? makes for a really tidy wiring harness , and no plug wires. I think I found that the ignitor is built into the coil, so if the kit carlson controls coil dwell then you could be good to go. |
DNHunt |
Oct 9 2004, 06:32 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Kit's system is wasted spark so it's gonna fire the coil twice in each 4 stoke cycle. That might be a problem at high RPMs
Dave |
machina |
Oct 9 2004, 07:57 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Man that motor looks expensive.
Lo-Fi Version | Time is now: 6th June 2024 - 11:51 PM |
