Race Suspension, Spring & Torsion bar rates |
911/914 |
May 14 2003, 12:26 PM
Newbie Group: Members Posts: 3 Joined: 13-May 03 From: Rochester NY Member No.: 690 |
Trying to find some help with chosing the right springs and torsion bars to use for a 914/4 vintage racer ?
john rogers |
May 14 2003, 12:45 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
My car weighs 2278 pounds and I use 23mm t-bars in the front and 300# springs in the rear with Koni Sport shocks all around. I use slightly heavier springs since my car uses slicks and gets more grip than a car with v700s or something similar. I had to go with the rear 300# springs since the car was lifting the front wheel easily even with a roll cage in the car and they keep it flat. This works well for most of the tracks I race at in So Cal area such as Willow Springs and CA Speedway which are flat and smooth. At PIR in Az the car was a little too stiff and wanted to push some in the corners so I couldn't go flat out like the softer sprung cars could. What do the east coast guys run??? Good luck
campbellcj |
May 14 2003, 05:42 PM
I can't Re Member Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I haven't tried this configuration yet, but I am putting in 22mm front t-bars and 225lb rear coil-overs for my next event.
Also keep in mind that your swaybars and tire types/sizes, as well as the track layout and conditions, all are important variables in sorting this stuff out. I currently have a Weltmeister 22mm front swaybar and no rear bar. As John hinted, if you go too soft you might not be taking full advantage of your tires' traction due to extreme body roll and weight transfer. But if you go too hard then I think you can "overwhelm" the tires and skate or bump right off the track. My car is a tad lighter than John's and has less torque, and I run DOT tires vs. slicks. So I think a 200-250lb spring rate is probably about where I want to be. |
TimT |
May 14 2003, 06:34 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
I have #450 fronts #350 rear spring on my 914/6 w/3.2. The car doesnt push at all, and throttle steers really well. I think if my car had a 4 banger id be using much lighters springs.
Zeke |
May 14 2003, 09:22 PM
Never left, but not right.... Group: Members Posts: 382 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
This doesn't get brought up much, but the wider your track on front and rear, the more bar/spring you need to stay the same as a narrow car. 22/200 should be plenty for a narrow 4 cyl car. At least that's what I think 'cause that's what I have. But you can't listen to me, I haven't driven the car yet! Hah! (IMG:style_emoticons/default/laugh.gif)
john rogers |
May 14 2003, 09:31 PM
Since you need to drive it some Milt, are you coming out to the CA Speedway vintage race next month on 6/21, etc.?????
Lo-Fi Version | Time is now: 13th June 2024 - 04:23 AM |
