TA bushings bad?, How can I tell if they're bad? |
ewdysar |
Jan 10 2005, 06:12 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
My car feels kinda like it's getting small steering inputs from the rear while freeway cruising on smooth and level stretches. I'm figuring that it's the trailing arm bushings (probably original). I guess it could also be a twitchy alignment, or just me getting used to a real sports car again.
How can I check the TA bushings for play without major disassembly? If they're bad, I'm probably going with Mueller bearings. Mueller, where are the rear bearings available? I checked them out once with a link in your signature file, but that link's gone now... Thanks, Eric |
SLITS |
Jan 10 2005, 06:16 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
On a lift, push to and fro on the tire........you will see the TA moving at it's piviot point.
Aaron Cox |
Jan 10 2005, 06:24 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
what doofmeiester says (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
jack up the side of the car... pus and pull on the trainling arm. i had the same issue..dead bushings. look for ovaled suspension ears too (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Mueller |
Jan 10 2005, 06:48 PM
I'm out of stock right now....Tarett Engineering has some in stock
if the bushings are that bad, you should be able to jack the car up and check by grabbing the end of the t/a and shaking it.... |
skline |
Jan 10 2005, 06:49 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Pus and pull? I can see you are getting lots of work done Aaron. How is that project coming?? |
Aaron Cox |
Jan 10 2005, 06:58 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) call me on an effin typo...
project is ok... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
skline |
Jan 10 2005, 07:08 PM
I wouldnt have except there were a couple of them in just that one post. So I figured you were either slipping or illiterate. Knowing you, I assumed the first. |
Aaron Cox |
Jan 10 2005, 07:11 PM
thanks scott (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Twystd1 |
Jan 10 2005, 07:17 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Where do you buy effin typo's???
Do I need them on my car like you guys to go fast???? Do they come in chrome? Does Tarret sell em? And do I have to shake my tires to see if I have bad ones? Twystd1 (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 09:18 PM |
