buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
on a recent post a guy was getting the inside of the gas tank "Renue". I call up my nearest Renue guy and showed him my tank. He said he would have to cut up the tank in order to get to all the places in the tank. He said to get to all the baffles and under the pan he would have to cut holes in the tank. I read where a guy mention a product called caswell plating kit for gas tanks. I made a electrode and used vinegar and a battery to collect the rust. Can I use a slosh and swirl product like caswell to do a good job or does the venue guy have it right?
johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
Buck....
yes there is a baffle mid line in the tank to stop slosh weight trasfer from left to right in the tank....also a round baffle around the fuel line pick up / return holes how bad is your tank? try cleaning your tank first.... I have had good luck over the years using muratic acid to wash out the inside of many fuel tanks..... it will eat the rust off and leave the inside very clean. You just have to be very careful using it....very corrosive and will burn your skin....so safety precautions need to be in place... take all the fittings off the tank and plug up the fuel line holes....pour in and slosh around....rinse out with lots of water.... I have tried sealers and they just don't seem to work very well... really best to find another tank if yours is so bad with pin holes and lots of rust.... |
Optimusglen |
Senior Member ![]() ![]() ![]() Group: Members Posts: 923 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest ![]() ![]() |
I had Gas Tank Renu do my tank.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1469570713.1.jpg) Easily worth it. Nice to have something I'll never have to worry about. If they did cut holes in the tank, they welded them flush so that I can't tell. Outside looks like a brand new tank, inside too. Lifetime warranty too. I started down the route of cleaning mine out myself, but it was a major pain, and then you get to try and dispose of chemicals. |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Use phosphoric acid, sold at Home depot as concrete etch, usually by the concrete stains. . It's a green liquid and is around $12 a gallon. . It also converts rust as well as cleans. . leaves your tank shiny like new. . It's the active ingredient in Rust-X and other rust treatments.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I just cleaned two rusty motorcycle tanks worth about $800/each. I filled them to the top with apple cider vinager. Put the cap on and let them sit for 2 weeks. Then I rinsed them out with water and baking soda to neutralize the vinager. The inside of the tank looks like new metal. I rinsed it with marval mystery oil to keep it from rusting.
The vinager takes a bit longer than other chemicals but I can keep the tanks sitting in my garage and then pour the used vinager in the woods without any hazmat issues or complaints from the wife. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I just cleaned two rusty motorcycle tanks worth about $800/each. I filled them to the top with apple cider vinager. Put the cap on and let them sit for 2 weeks. Then I rinsed them out with water and baking soda to neutralize the vinager. The inside of the tank looks like new metal. I rinsed it with marval mystery oil to keep it from rusting. The vinager takes a bit longer than other chemicals but I can keep the tanks sitting in my garage and then pour the used vinager in the woods without any hazmat issues or complaints from the wife. I am starting to believe that apple cider vinegar is one of the magical lost secrets of our time. I am on a quest to reduce salt in my diet and apple cider vinegar keeps coming up as the substitute, and it does a good job for many of the functions of salt. Amazing it removes rust too. Rich |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Apple cider vinegar is an almost instant cure for leg cramps. Sorry for the highjack. (IMG:style_emoticons/default/dry.gif)
r_towle |
Gallstones and cholesterol if you want to drink it straight.....
It's magic. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,781 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Gallstones, gas tanks, leg spasms, sugar substitute, rusty hardware, chicken salad,
where will it end ? Seriously though, at less than a buck a gallon you can fill a trash can half way and practically renew all your brackets, hardware,wheels etc.etc. Removes rust but not paint. |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
Apple Cider Vinegar is the way to go. I've done several tanks. |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Where do you guys purchase 16 gallons of Apple Cider Vinegar from? Our small town IGA sells the stuff in 32oz bottles for like $5 a pop!
That would be 64 bottles at $320 (IMG:style_emoticons/default/blink.gif) Not mention the fuel driving to 3 to 5 towns to corner all the Apple Cider Vinegar market. |
mepstein |
I get 1 gallon jugs at the market for $2..
So each moto tank cost me about $10. A 914 tank would cost me $50 if I needed to fill to the top but it would mean no cutting of the tank. Lots of tanks are just rusty at the bottom. Bigger super market maybe? Not the only way, just works for me. |
mbseto |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,257 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States ![]() |
Just fill it halfway, let it sit for a while and then flip it over. Or do it in thirds... I used the electrolysis method to remove most of the rust, been debating how to finish it off... Might try this vinegar thing...
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,492 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
on a recent post a guy was getting the inside of the gas tank "Renue". I call up my nearest Renue guy and showed him my tank. He said he would have to cut up the tank in order to get to all the places in the tank. He said to get to all the baffles and under the pan he would have to cut holes in the tank. I read where a guy mention a product called caswell plating kit for gas tanks. I made a electrode and used vinegar and a battery to collect the rust. Can I use a slosh and swirl product like caswell to do a good job or does the venue guy have it right? I used phosphoric acid and in another tank I used an organic based stuff that went for about $25 per gallon. Diluted with water you can fill the tank. I made seals at all the ends and then left the tank in the sun. Looked like a dead seal on the lawn. Then I put the tank on a rotisserie filled with chain bolts big nuts and WD-40 and turned it with a slow gear motor. Or a drill. Makes a hell of a noise. I count the pieces as I put them in and take them out. The results have been spectacular, but I cannot find the photos. I distust any organic liner on the steel because it could start peeling off. Not that I know of such an instance, but I have never seen a truly permanent paint. This is surrounded by gasoline. |
Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,219 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
GasTank Renu did mine following the procedure you outlined. Once they make the cutout(s) they supposedly also media blast the inside before chemical treatment the claim being that it gives a better surface for the sealant to adhere to. They weld the cutouts back in place and also coat the outside of the tank with a material that feels like hardened undercoating. I had them leave the exterior top of the tank unfinished and just hit that with black paint.
I did not want to deal with all the nasty chemicals and wanted to minimize chance of the interior coating peeling. They seemed to do a vary thorough job. I only had it done last year so can not speak to long term durability. I also agree that if you are just cleaning up the tank, probably best to leave it uncoated. However, if metal is thin or there are pinholes you may have no choice. Avoid ethanol fuel if you can, that is the root cause of many failed tanks. |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Where do you guys purchase 16 gallons of Apple Cider Vinegar from? Our small town IGA sells the stuff in 32oz bottles for like $5 a pop! That would be 64 bottles at $320 (IMG:style_emoticons/default/blink.gif) Not mention the fuel driving to 3 to 5 towns to corner all the Apple Cider Vinegar market. I was wondering the same thing. (IMG:style_emoticons/default/laugh.gif) So I stopped at a Walmart. They sell their brand apple cider vinegar for about $4.00/gallon and their brand white vinegar for about $2.50/gallon. Is white vinegar an acceptable substitute for apple cider vinegar? The vinegar container labels don't say anything about fuel tank rust removal. (IMG:style_emoticons/default/rolleyes.gif) Let's see: 17gal x $2.50/gal = $42.50 17gal x $4.00/gal = $68.00 Not too bad I guess. (IMG:style_emoticons/default/idea.gif) |
johnhora |
buck toenges |
So I don't need to coat the inside of the tank after it is cleaned? I sort of like the coating with the marvel mystery oil. Does the mystery oil affect the gas?
Buck |
mepstein |
Jeff Hail |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 ![]() |
I just cleaned two rusty motorcycle tanks worth about $800/each. I filled them to the top with apple cider vinager. Put the cap on and let them sit for 2 weeks. Then I rinsed them out with water and baking soda to neutralize the vinager. The inside of the tank looks like new metal. I rinsed it with marval mystery oil to keep it from rusting. The vinager takes a bit longer than other chemicals but I can keep the tanks sitting in my garage and then pour the used vinager in the woods without any hazmat issues or complaints from the wife. I am starting to believe that apple cider vinegar is one of the magical lost secrets of our time. I am on a quest to reduce salt in my diet and apple cider vinegar keeps coming up as the substitute, and it does a good job for many of the functions of salt. Amazing it removes rust too. Rich ACV is called the "Mother" for various reasons. Besides industrial uses and salad dressing it is clearly magical. Its been used for thousands of years. Its good for the blood, balances insulin levels, balances electrolytes (sodium) , works on indigestion, add Vit C and it will cure scurvy, gets rid of pet urine smell, women use it for yeast infections but will never admit they have the bread thing, use in place of shampoo and hair will never get dry, works great on sunburn (I know), sore throat, foot fungus, post exertional workout as it breaks up lactic acid. |
Lo-Fi Version | Time is now: 16th July 2025 - 04:42 PM |
