| 7TPorsh |
Sep 16 2016, 10:20 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I used search but everything I found had to do with in dash radios. I removed the heater controls and radio space to put in an array of vdo gauges. I don't have a center console.
Now that I have been successful quieting up the car I want to put in some tunes. I want to keep my glove box working so need other ideas. Either a radio....or a way to play music from my phone. |
| Optimusglen |
Sep 16 2016, 10:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest
I'm going to use one of these in my build. DROK mini amplifier.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1457362751.1.jpg) It's just an AUX-IN with a volume knob. You supply it with 12v, and run the speaker wires. Here it is on my radio delete plate next to a couple stop watches. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1461521472.1.jpg) If you've quieted up your interior a lot it should be enough volume. |
| ConeDodger |
Sep 16 2016, 10:29 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,609 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
Not exactly sure what McMark is using under the dash, but I know his iPod bluetooths to 'it,' whatever it is, and McMark has quite the music collection to choose from...
Contact him and ask. Probably similar to what Glen is using. |
| 7TPorsh |
Sep 16 2016, 12:25 PM
I'm going to use one of these in my build. DROK mini amplifier. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1457362751.1.jpg) It's just an AUX-IN with a volume knob. You supply it with 12v, and run the speaker wires. Here it is on my radio delete plate next to a couple stop watches. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1461521472.1.jpg) If you've quieted up your interior a lot it should be enough volume. This is an awesome find....under $15. Probably cleaner output than using bluetooth. The others I have seen have a larger panel; this is only a volume and jack. Does it work well for you? Enough power output? Have to crank Van Halen's first album; only way to listen to it is at 98db! |
| Mark Henry |
Sep 16 2016, 01:55 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
You will need an amp with that solution.
Woody's has ipod, mp3 with different amps. http://stores.ebay.com/Woodys-Custom-Shop/...d=p4634.c0.m322 |
| Andyrew |
Sep 16 2016, 01:59 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
I would combine something like that with a small amp just to provide a more stable sound.
Thats what Im planning on doing. I have this combined with a 1k (Probably go down to a 650watt) watt amp that I am going to install. Bluetooth was a must for me. Receiver https://www.amazon.com/gp/product/B01ANFOOV...=UTF8&psc=1 Vol Knob https://www.amazon.com/PAC-LC-1-Remote-Ampl...+volume+control This is another option that I considered for my setup. Lots of options like this out there for boats. Hide the volume control in your center console and be good to go. https://www.amazon.com/Pyle-PLMRMBT5S-Bluet...plifier+600watt |
| Chris914n6 |
Sep 16 2016, 02:14 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,558 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
If that little amp doesn't work for you then look at this.
Solely a volume knob. Add an earphone to rca cable to the player and an amp to the speakers. The new digital amps are small enough to fit in the center console with plenty of top off power. Knob comes off so you can also mount it in the dash. ![]() |
| Mike Bellis |
Sep 16 2016, 04:25 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
| rgalla9146 |
Sep 16 2016, 04:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,998 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Dual amps, dual speakers, no antenna
Attached thumbnail(s) |
| johnhora |
Sep 16 2016, 04:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 908 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
| Mark Henry |
Sep 16 2016, 05:53 PM
I'm going to use one of these in my build. DROK mini amplifier. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1457362751.1.jpg) It's just an AUX-IN with a volume knob. You supply it with 12v, and run the speaker wires. Actually that's not that bad looked at the reviews on amazon, they come in 10wx2, 15wx2 and 35wx2, the 35x2 is $20. Cons is it's for car audio so it runs better at 14v (if you're thinking PC audio, 12v), it gets hot and no case. Also it won't run a subwoofer and is only 2 channel. Pro is it doesn't distort at high volume, sound is pretty good and it's 20 bucks. |
Lo-Fi Version | Time is now: 12th October 2026 - 01:10 AM |
