tripple weber q's |
tripple weber q's |
Jeroen |
Apr 27 2005, 05:42 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
started cleaning my webers...
when ordering a rebuild kit for tripple throat webbers, what should I look for (what needs to be in the kit) when is it time to get the butterfly shafts rebuild? There is some movement at the linkage end of the shaft last but not least... one of the airbleed screws has broken off in the carb body (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (I didn't do it, I took 'em off the car like that) I already tried to cut a slot in it to get a screwdriver in, but the screw is soft and stuck pretty nasty Any ideas? Or should I just take it to a machine shop (I don't feel comfortable drilling it out myself) Attached image(s) |
Jeroen |
close up...
Attached image(s) |
seanery |
Apr 27 2005, 05:44 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Jeroen,
contact PMO for a rebuild kit...Rich is a good resource if you can get him on the phone. |
TimT |
Apr 27 2005, 05:53 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
the rebuild kit will have the gaskets, o-rings, diaphragms for the accel pumps etc.
The shafts should have been checked while on the car, and the car running. spray some carb cleaner at the shafts while the car is idling. If the idle speed changes after a shot of cleaner, you should have the shafts rebushed. Sinces the carbs are off the car just grab the shaft and try to wiggle it if if moves just a teeny bit the shafts are fine, but if you can actually see and feel the shaft moving, they need to be rebushed Id try some heat on the air bleed screw, and see if that works... otherwise send it off to a machine shop |
sixnotfour |
Apr 27 2005, 08:13 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
FYI Beiker Engineering in Grants Pass , Oregon charges 950.00 approx. to rebush, replate hardware and rebuild em ready to go.
Gint |
Apr 27 2005, 08:27 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
It's quite possible that you've already reached that point. Save yourself the headache (ask me how I know) and just send 'em off and have them rebushed and rebuilt all at the same time. Start fresh and new. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:11 AM |
