replacing injectors |
87m491 |
May 1 2017, 04:31 PM
Member Group: Members Posts: 275 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Working my way from the gas tank to the engine replacing every soft fuel delivery component. Just got my injectors back from Mr Injector and looking to reinstall.
Needless to say on removal the tip seals were toast, I'm surprised the car ran as well as it did. the injector almost fell out with no effort. (74 2.0) Went to reinstall yesterday with new tip seal installed on the injector and I couldn't get them to seat try as I might. After taking a mirror and looking. I saw the cavity for the tip seal is not very deep. I finally hit on seating the seal alone and inserting the injector through it. The left side injectors "seated" with a firm seal and very little play afterward. On the right side the seals barely were able to remain unaided in the seat cavity before I inserted the injectors. They did seat in as positively as on the other side. Certainly nothing like what you get with O ringed CIS injectors. Is there any trick or is this just the way they are? With the retainers on, both sides seem exactly the same and very locked in. thx mike (IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1493677908.1.jpg) |
dangrouche |
May 1 2017, 04:57 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
small "o" ring on the tip and a thicker cylindrical one on the the bracket. that's about it. almost seems like its just laid on, but this is the way it is. not tightened down like brake lines need to be.
r_towle |
May 1 2017, 06:47 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
its the way it is....and it works.
You are trying to make sure there is no vacuum leak...that is key. rich |
87m491 |
May 2 2017, 05:52 AM
mihai914 |
May 2 2017, 07:18 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
You can also remove the intake runners and install the injectors outside of the car. Just be careful with the wavy washers not to loose them in the intake.
Lo-Fi Version | Time is now: 1st June 2024 - 04:19 PM |
