Sway Bar Installation, Does the fuel pump interfere? |
Allan |
May 12 2005, 05:07 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I was looking at buying and installing a front sway bar but was wondering if the fuel pump will interfere. Have have the one up in front.
Pic Attached image(s) |
Aaron Cox |
May 12 2005, 05:20 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
shouldnt..... they did put swaybars on 75 and 76 cars ya know (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
HTH |
skline |
May 12 2005, 05:24 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Nope, it wont interfere at all. Same sway bars on all years.
Allan |
I know, I know. I just wanted to make sure that If I had to relocate it, I could find out how big of a PITA it was gonna be.
MoveQik |
May 12 2005, 05:25 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Mine is a 75. I had the Weltmeister sway bar installed. No issues at all.
Allan |
Okay then, I'm all over it like rice on stink.
Allan |
May 13 2005, 08:05 AM
Okay, next question. If I install a stock size sway bar, can I upgrade later with just a larger bar and still use the stock drop-links and stuff?
Eric_Shea |
May 13 2005, 08:35 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
If it's a factory bar yes but, there aren't too many options there. The 18mm 76 Turbo bar is the only real through body factory upgrade. They had reinforced arms (not sure if it's totally necessary but I have them on both mine). If you upgrade to a larger bar, most of them come with their own arms and links.
MarkG |
May 13 2005, 10:48 AM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
Just repalced my stock sway bar w/ Weltmeister a 22mm and in interfears with the gas tank - will have to move up the tank a bit.....
maf914 |
May 13 2005, 11:07 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Was this due to the increased bar size or because the tank may not have been level in the rubber blocks? There is room for adjustment when positioning the tank and rubber blocks. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
RustyWa |
May 13 2005, 12:57 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
If you worry to much about hitting the fuel pump, you might actually raise it to much and hit the tank.
Mine is close, but it clears. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
bmcwilli |
May 14 2005, 06:11 AM
Member Group: Members Posts: 133 Joined: 28-April 05 From: Chapel Hill NC Member No.: 3,998 |
What about a swaybar and the dpd AC condensor (the one with the plastic cover that looks like a silly black hat)?
Can I install a swaybar with the condensor in place? |
maf914 |
May 14 2005, 06:26 AM
The sway bar will be behind the bulkhead through the inner fenders under the tank, while the condenser is in front of the bulkhead. There should be no interference at all between the bar and condenser. But, some AC installations routed the AC hoses along the inner fenders in the wheel wells. These may be in the location where you place the sway bar brackets, so you may have to pull the hoses out of the way. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:20 AM |
