How do I lower the back end of my car? |
MoveQik |
May 12 2005, 06:01 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I just had new 140#springs put on my car and it sits higher than it did before. I'm told it is because my old springs were sagging when compared to the new ones. I have KYB gas adjust shocks on it. Any one have any ideas on what it takes to get the back end down to reasonable height? I was told to cut the springs but I would hate to do that to a brand new pair. Seems sorta like a half-assed way to fix the problem.
You can see how it sits if you go to my blog. |
SLITS |
May 12 2005, 06:06 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Looks like new shocks with adjustable spring perch...or cut the springs....generally, the 140 lb springs are a shorter coil and drop the ass 1" or so over stock.
Mueller |
May 12 2005, 06:31 PM
nice looking car...the front needs to be lowered just as bad as the rear (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Ron is correct, about the only reasonable method is replace the shocks or modify the springs(not recommened).... The KYB's can be converted to adjustible coil-overs, however if you have to pay someone to do them, then there will be no cost savings. |
Mike D. |
May 12 2005, 06:57 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
You could try adding a dead body to the trunk... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I know...no help at all (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
TravisNeff |
May 12 2005, 07:14 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Michael,
I just took a peek at your blog and photos of your car, very nice! Adjustable perches with springs run around $250 (www.paragon-products.com), the springs are included and replacements in other sizes are pretty cheap ($60). They have them for Bilsteins and Koni shocks, I am not sure about the KYB's - that will depend on if the lower perches can be removed and the diameter of the shock body. I have koni sports and the adjustable perches, I love them. |
MoveQik |
May 12 2005, 08:55 PM
Damn it all! One thing always leads to another. I finally get my car back on the road after two years of being torn apart. My car sits just fine but I think "Maybe I'll stiffen up the rear a little since the front is handling so well with the new sway bar"
Easy enough, just buy springs that are more firm. But NOOoooOOOOooOOoooo. Now I gotta get new shocks. This is getting difficult to justify to my wife! I can already see it coming. I'll get the rear where I want it but the only way to get the front down will be to buy stiffer torsion bars. And once it gets handling so well, I'll have to buy better tires. Then the brakes will be the weak link...911 vented roters perhaps? Of course that means a 5-lug conversion. While I'm at it, I might as well go wide with the rims....uh oh, I think I hear rumors of flared fenders! Now the cars looks like a rocket but it is still a stock 1.8 liter. Perhaps a 6 conversion? Yeah, thats it! I quit. For sale: 1975 1.8 pre-runner looking 914. |
URY914 |
May 12 2005, 08:57 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
xsboost90 |
May 12 2005, 09:05 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
get some adjustable rear shocks...much easier to reverse.
Attached image(s) |
bd1308 |
May 12 2005, 09:07 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
you all are wrong, go over to home depot and buy 10 bags of cement....put it in the back and BINGO....lowered rear end
Type 4 Unleashed |
May 12 2005, 10:53 PM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) You are all wrong, drop in a V8 and it will sit just right. Kidding aside, you can adjust the upper spring plate, up as far as you can, leaving enough threads, to get the nut on the top side. With it adjusted like that the spring will flop around, while its out of the car, but mounted, it's fine. Make sure the spring ends are positioned so when you lower the car, there in the correct position in the plates. If's thats's still not enough? You can trim, the rubber gromets, and adjust the plate, as before, leaving enough thread to get the nut on top. You should be able to lower it this way, over an inch. Looked at your car, very NICE To get a square peg in a round hole, drive over it with a 914. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
GWN7 |
May 12 2005, 11:00 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Are you related to Dirk Wright perchance? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Or so, if you wanted a car to just drive and not work on you would have bought a Kia. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
TravisNeff |
May 12 2005, 11:02 PM
Do the KYB shocks have adjustments (for the circlips) like the Koni's do?
Borderline |
May 12 2005, 11:03 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
What brand springs did you buy? I picked up some weltmeister 140# from ebay and finally got them installed and the rear is still taller than I would like. The springs have a change in pitch as the coils were wound. It appears that the top 3 coils (with the close spacing) go solid when the car is sitting on the ground. My belief is that those coils were placed there to keep the springs from hanging loose when the car is jacked up but do not efect the spring rate when the car is on the ground. If I'm correct...???? then one or two of those coils could be removed without changing the final spring rate. The ride height would be reduced by the diameter of the spring wire. The problem would then be that when you jack up the car the spring would rattle loose. If all the coils on the spring have the same spacing then this wouldn't work. any comments???? anyone?
TravisNeff |
May 12 2005, 11:05 PM
You zip tie the springs to the upper perches and that solves the problem.
SLITS |
May 12 2005, 11:09 PM
If you cut them, you can snap tie the coil to the lower spring perch. They will reseat correctly. This is done with racing springs that are shorter than stock.
KYB (Kill Your Back) shocks, being gas charged, will always be in the full extended position, whereas others that just dampen the rebound (Konis) will sit lower as they have minimal resistance on compression and the spring will take more of the weight of the car. or In lieu of all this, get over it and raise the front end. |
dlo914 |
May 12 2005, 11:11 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
the best and simplest method would be to purchase some adjustable shocks (bilsteins have 5 IIRC height settings). they're available on the forum's ecomm store for about $250. The same situation occured when i installed some 140lb weltmeister springs, and now the front and back sit level.
anthony |
May 12 2005, 11:14 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
That's about the sequence of events! It's a shame though to have KYBs on such a beauty. It at least needs Konis or Bilsteins with the adjustable rear spring perches. And as Mueller said, it needs lowering all the way around...bad. |
Type 4 Unleashed |
May 12 2005, 11:31 PM
Do, you know what you forgot? Big Giant Expensive, Front and Rear Sway Bars. So it will handle with the 6 conversion (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) OOH YEA, and the droped spindels (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) You do know how to lower the front end? |
MoveQik |
May 12 2005, 11:37 PM
Never heard of Dirk. Never complained about working on the car. Just making making fun of how one thing always leads to another....sorta like any project I start on my house. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
mightyohm |
May 12 2005, 11:39 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
The most cost effective option by FAR is to get a pair of Bilstein's for the rear. They allow you to set the height in 1/2 or 1" increments (I forget) and will give you plenty of adjustment range. I was able to find them for $96 ea. (shox.com)
Lo-Fi Version | Time is now: 9th June 2024 - 08:52 PM |
