> Anyone recognize these rear springs?, Very blue...
arne
post Jun 17 2017, 02:41 PM
Serial Rescuer of old vehicles...
I got a pair of these in a batch of misc. 914 parts. Or rather, we think these springs are for 914. Very blue, 1/2" wire, 14" free length, about 7 coils (allowing for the flattened ends), correct diameter for 914 at 4.25" (110mm?). Seems like they'd be rather stiff. Anyone recognize them? Need to figure out what they are before I offer them for sale.
SixerJ
post Jun 17 2017, 03:22 PM
Region Association: England
http://m.ebay.de/itm/Porsche-914-914-6-Fed...%257Ciid%253A19
arne
post Jun 17 2017, 03:37 PM
Those are similar color, but lots more coils and thinner wire.
ConeDodger
post Jun 17 2017, 04:11 PM
Apex killer!
Look like Weltmeister 140# springs... Mine had the number 140 on the outside of the spring coil.
arne
post Jun 17 2017, 05:37 PM
I looked again at both springs carefully, Rob. No marking at all. Drat! The Weltmeister 100 lb. I put on the rear of the car are black and well marked, both brand and rate.
The 100 lb. springs are 11mm wire, these blue are a full 1/2" (12.7mm). so probably at least 140 lb., perhaps more.
Would be nice to know for sure though.
TheCabinetmaker
post Jun 17 2017, 06:39 PM
I drive my car everyday
A 140 lb spring will compress 1" when 140 lbs is applied.
r_towle
post Jun 17 2017, 09:33 PM
Custom Member
They can be tested
KevinW
post Jun 18 2017, 06:10 AM
I have a similar set, mine are black with a gray stripe.
14 1/8" long and 7/16" wire.
Optimusglen
post Jun 18 2017, 11:10 AM
You can calculate the spring rate pretty easilly. you need the free length, , number of sprung coils, wire diameter, coil diameter, and end style. You can guess on material since all of the steels are pretty close.
Http://www.thespringstore.com/spring-calcu...calculator.html
Chris914n6
post Jun 18 2017, 12:38 PM
Jackstands are my life.
Look like the 200lb springs RH was selling back in my day.
arne
post Jun 18 2017, 01:00 PM
QUOTE(Chris914n6 @ Jun 18 2017, 11:38 AM) *
OK, that sounds likely. The guy I got these from has had them a long time, and had no info on them from the guy he got them from. I've used a few online calculators and all have come up a bit over 200 lb/in.
As a 914 noob, who is RH?
maf914
post Jun 18 2017, 05:45 PM
Not a Guru!
QUOTE(arne @ Jun 18 2017, 11:00 AM) *
I really don't know, but RH might be Renegade Hybrids who do V-8 conversions and parts. Just a guess. (IMG:style_emoticons/default/idea.gif)
TheCabinetmaker
post Jun 19 2017, 12:09 PM
Restoration design
- Lo-Fi Version Time is now: 11th July 2025 - 03:47 AM
