> Return fuel line with carbs?, Anyone running return fuel line with cabs?
lonewolfe
post Feb 3 2018, 07:06 PM
Are any of you running a retun fuel line with carbs?
struckn
post Feb 3 2018, 08:38 PM
I'm not running a return line...actually I had Translog GT replace the Plastic Lines with Stainless and they put the Stainless feed line in but left the return line in, disconnected, should the car ever need it in the future.
brant
post Feb 3 2018, 08:51 PM
Yes.
A return fuel line in s a good thing.
Keeps the fuel entering the carb cooler
Potentially more up and less vapor lock
Perhaps not noticeable but? Still better andthere is a reason all factory systems use a return
Larmo63
post Feb 3 2018, 09:05 PM
On a six with Webers, I'm not sure how it works?
Splain? (IMG:style_emoticons/default/blink.gif)
jcambo7
post Feb 3 2018, 09:45 PM
QUOTE(Larmo63 @ Feb 3 2018, 10:05 PM) *
On a six with Webers, I'm nt sure how it works?
Where would the return line attach to on the carbs?
porschetub
post Feb 3 2018, 11:11 PM
QUOTE(Larmo63 @ Feb 4 2018, 04:05 PM) *
(IMG:style_emoticons/default/agree.gif) tell us more????.
mmascari
post Feb 3 2018, 11:17 PM
QUOTE(porschetub @ Feb 3 2018, 09:11 PM) *
I guess its not needed on a six but I am running a fuel pressure regulator that has a return on it so I have it connected back to the gas tank.
brant
post Feb 4 2018, 08:19 AM
QUOTE(Larmo63 @ Feb 3 2018, 08:05 PM) *
Krieger
post Feb 4 2018, 10:59 PM
To be clear the rectangle is the filter. Circle is the pump. Triangle/ hex is the regulator. Right Brant?
gothspeed
post Feb 5 2018, 12:21 AM
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif)
But it would depend on the type and range of regulator. Second choice would be option D with a Y feeding carbs.
lonewolfe
post Feb 5 2018, 12:41 AM
I have Dellorto carbs so one has the menu intake line & a double banjo that then feeds the second carb. I was thing if both carbs had double banjo’s that the second outlet on the the slave carb could run as a return line. Do you guys think that would work ok? I do not believe my fuel pressure regulator has an option for a return line.
bbrock
post Feb 5 2018, 08:27 AM
QUOTE(gothspeed @ Feb 4 2018, 11:21 PM) *
But it would depend on the type and range of regulator. Send choice would be optio D with a Y feeding carbs.
To make sure I understand correctly, C and D would require a bypass style regulator while B and E would use blocking type. Do I have that right?
gothspeed
post Feb 5 2018, 08:42 AM
QUOTE(bbrock @ Feb 5 2018, 06:27 AM) *
Yes, there are regulators that 'send out' a regulated target pressure (inline) and some that 'bleed out' anything over your target pressure (return). (IMG:style_emoticons/default/smile.gif)
ChrisFoley
post Feb 5 2018, 08:46 AM
I am Tangerine Racing
QUOTE(bbrock @ Feb 5 2018, 10:27 AM) *
Yes, except that in option B the upstream regulator is useless. A blocking regulator is needed downstream.
We had a 914 here recently which came with a single carb that had an internal regulator. It needed the return line to work.
Otherwise I don't think I've ever seen a 914 with a carb setup in my shop (other than stock 914-6) that used a return line.
anderssj
post Feb 5 2018, 09:48 AM
Dog is my copilot...
I've been running dual dell's with an "option C" return line since the early 1980s . . . works well. (IMG:style_emoticons/default/smile.gif)
bbrock
post Feb 5 2018, 10:22 AM
QUOTE(Racer Chris @ Feb 5 2018, 07:46 AM) *
And that answers my next question about option B (IMG:style_emoticons/default/biggrin.gif) I'm planning to run a return line on my carbed /4. I might want to switch back to FI in the future so it seems like a good way to future-proof the setup. Plus, I like the idea of a return line anyway.
brant
post Feb 5 2018, 12:37 PM
QUOTE(Krieger @ Feb 4 2018, 09:59 PM) *
correct
Socalandy
post Feb 5 2018, 09:54 PM
Its got to be Yellow!!!
covered here, im running tangerine lines with PMO regulator. Works great (IMG:style_emoticons/default/aktion035.gif)
http://www.914world.com/bbs2/index.php?showtopic=246855
North Coast Jim
post Feb 6 2018, 08:09 AM
No return line in use with 44 IDFs. Car runs great after sorting out the jetting issues. I used the tunnel grommets to run a 2 conductor wire for power as the fuel pump was relocated to the front under the gravel panel.
1adam12
post Feb 21 2018, 11:03 AM
What's up guys! I just purchased a pair of Dell 40's which I'm currently rebuilding at the moment. I like the idea of running a fuel return for 1.7 as some have discussed but my question has to do with the fuel pump and regulator set up. Can you run a low pressure (rotary style) fuel pump i.e. (CB Performance / Carter) with Option E and delete the regulator from the drawing? Or would I need to keep a high pressure set up with a good aftermarket regulator like Mallory ect. to make up for the amount of flow for the return and not flood the carbs?
- Lo-Fi Version Time is now: 25th May 2026 - 07:36 AM
