perfect fit tail lights and tail light bodies are here, we are happy to finally get them |
dr914@autoatlanta.com |
Aug 1 2019, 02:15 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
these fit and look great, finally a solution to the old tail light bodies and now perfect fit lenses as well [attachmentid=706
970] Attached thumbnail(s) |
Ferg |
Aug 1 2019, 02:21 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Let's see them mounted on a car
thelogo |
Aug 1 2019, 02:46 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
914Sixer |
Aug 1 2019, 03:49 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Looking Good (IMG:style_emoticons/default/popcorn[1].gif)
FlacaProductions |
Aug 1 2019, 04:05 PM
Senior Member Group: Members Posts: 1,616 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
jagalyn |
Aug 1 2019, 04:15 PM
True Patina Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None |
George, Thanks for producing these. If they truly seal up the water issues that have plagued the 914 for the last 50 years that will be a great contribution to many who love these cars.
raynekat |
Aug 1 2019, 09:39 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
George, are the tail light bodies on your site? How much for a pair?
bbrock |
Aug 3 2019, 09:43 AM
Have you considered selling just the reflector assemblies. I'll bet a lot of us have good housings with flaking and tarnished reflectors.
Aug 3 2019, 09:56 AM
usually by now the housings are brittle and or warped. The reflectors are a bit difficult to install because of the wiring, hence we just have the complete bolt in body.
Yes they are on our site along with the lenses Have you considered selling just the reflector assemblies. I'll bet a lot of us have good housings with flaking and tarnished reflectors. |
raynekat |
Aug 3 2019, 05:29 PM
I agree George....most used housings I've seen are toast. Many times people put in the wrong bulb that's too hot and end up melting the housing. Or the corners have been broken off. Or the rubber seal between the housing and the body goes bad, they leak water, instead of replacing the seal, people tighten the bejeezus out of the housing and end up cracking or tweeking the housing so that's it's ruined. I'd say those that just need the reflector are definitely in the minority.
Happy you are offering the entire assembly. I'll be buying a set soon to see how they look and fit. |
bbrock |
Aug 3 2019, 06:19 PM
I agree George....most used housings I've seen are toast. Many times people put in the wrong bulb that's too hot and end up melting the housing. Or the corners have been broken off. Or the rubber seal between the housing and the body goes bad, they leak water, instead of replacing the seal, people tighten the bejeezus out of the housing and end up cracking or tweeking the housing so that's it's ruined. I'd say those that just need the reflector are definitely in the minority. Happy you are offering the entire assembly. I'll be buying a set soon to see how they look and fit. I'll take your word. I haven't seen enough to know, but do the repros have this? It would be nice to be able to refurbish OE housings that are worth saving. I also think its great that compete units are being offered, but the notion that replacing reflector assemblies is too difficult is pretty silly considering what so many of us are doing with these cars. I get it if the market doesn't pencil out though. (IMG:style_emoticons/default/beerchug.gif) |
Jett |
Aug 3 2019, 07:00 PM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I agree George....most used housings I've seen are toast. Many times people put in the wrong bulb that's too hot and end up melting the housing. Or the corners have been broken off. Or the rubber seal between the housing and the body goes bad, they leak water, instead of replacing the seal, people tighten the bejeezus out of the housing and end up cracking or tweeking the housing so that's it's ruined. I'd say those that just need the reflector are definitely in the minority. Happy you are offering the entire assembly. I'll be buying a set soon to see how they look and fit. I'll take your word. I haven't seen enough to know, but do the repros have this? It would be nice to be able to refurbish OE housings that are worth saving. I also think its great that compete units are being offered, but the notion that replacing reflector assemblies is too difficult is pretty silly considering what so many of us are doing with these cars. I get it if the market doesn't pencil out though. (IMG:style_emoticons/default/beerchug.gif) G-Car (http://gcartrim.com/) will re-chrome the plastic... they re-chrome the early fog lights as well. Btw. George, great looking part! Do you have the housing to body seals that more closely resemble stock? |
Larmo63 |
Aug 3 2019, 07:02 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Shouldn't this be in the vendor or parts for sale section along with the dumb plastic 80's rocker covers?
Maybe Autos Atlanta should have a website? Oh, never mind. |
Jett |
Aug 3 2019, 07:03 PM
usually by now the housings are brittle and or warped. The reflectors are a bit difficult to install because of the wiring, hence we just have the complete bolt in body. Yes they are on our site along with the lenses Have you considered selling just the reflector assemblies. I'll bet a lot of us have good housings with flaking and tarnished reflectors. George, just looked and did not see the housings for sale. Attached thumbnail(s) |
scallyk9 |
Aug 3 2019, 08:19 PM
Member Group: Members Posts: 323 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
I also could not find the listings on the AA website.
raynekat |
Aug 3 2019, 11:25 PM
Search "914 tail light body" on the AutoAtlanta site and you'll find it.
They use the same pic for left and right, but they're there. |
bandjoey |
Aug 4 2019, 05:51 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
thanks for the heads up. planning on a little paint work in the fall and my 'good' tail lights have been resprayed with chrome paint and the plastic is crusty.
porschetub |
Aug 5 2019, 12:31 AM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Shouldn't this be in the vendor or parts for sale section along with the dumb plastic 80's rocker covers? Maybe Autos Atlanta should have a website? Oh, never mind. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) . |
Valy |
Aug 5 2019, 12:39 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
orthobiz |
Aug 5 2019, 03:31 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Other vendors introduce products in the garage area...I think they look great, George!
Paul |
Lo-Fi Version | Time is now: 9th June 2024 - 10:54 PM |
