Engine deck lid rain tray - Late style (fits all), 3 at $90+ shippping Will include mounting hardware and new catch |
Mikey914 |
Aug 7 2019, 11:44 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have 3 rain trays late style that is the one that superseded the early.
There are 2 versions of mounting hardware. This is dependent on the did you have. In summary the upper mounts (with hood in car) use screws in the late, but use a different version on the top. See below Note the screw where the early have a nut to accept a larger screw. So you will need to specify bolt or screw (later) New bonus latch shown before and after Attached thumbnail(s) |
Mikey914 |
Aug 7 2019, 11:57 AM
Installed my silver letters
Mikey914 |
Aug 7 2019, 02:15 PM
You will get the hardware correct for your deck lid, but you need to see if the center attachment (closest the letters) are smaller screws or large ones like the edge.
The bumpers should be replaced at the same time too and are included I have included the new bolts to attach the deck lid and even an extra washer I like to use to get more support. You can leave out if you wish, but it's there. Attached thumbnail(s) |
Jett |
Aug 7 2019, 04:03 PM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
You will get the hardware correct for your deck lid, but you need to see if the center attachment (closest the letters) are smaller screws or large ones like the edge. The bumpers should be replaced at the same time too and are included I have included the new bolts to attach the deck lid and even an extra washer I like to use to get more support. You can leave out if you wish, but it's there. Mark, do you have the rubber spacers for the tray? |
Mikey914 |
Aug 7 2019, 05:45 PM
I have the spacers for the rocker panels that George lists as the correct spacers. They look s bit big, also note that the nut the screw goes in holds it off even more. I can throw them in, but didn't use them on mine.
Mikey914 |
Aug 8 2019, 06:04 PM
2 left
Mikey914 |
Aug 8 2019, 08:38 PM
1 left
iankarr |
Aug 9 2019, 11:51 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
pm sent
Lo-Fi Version | Time is now: 11th June 2024 - 01:50 PM |
