1st time dropping engine, I'm using the tech article to do it. |
fatlando |
Jun 29 2005, 12:27 PM
Member Group: Members Posts: 259 Joined: 6-September 04 From: imperial beach, california Member No.: 2,700 |
I'm going to get to know my car this weekend and drop the motor and say" HELLO I"M YOUR MASTER....NOW QUIT FCKING WITH ME!"
I'm going to use engine drop article...from what I can read it's pretty easy... On another note, my 1st gear recently stopped working....anyone got a spare? I'll swap guitar lessons, nude pictures of the wife....first born child....or even worst....$$$$$ thanx to all for your support.... |
skline |
Jun 29 2005, 12:32 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Undo all the wires and hoses, remove the rear wheels and lower the car onto a piano dolly and remove 4 bolts. Then lift up the car and your engine is right there. Slide it out and teach it a lesson. Piece of cake and can be done alone. Good luck with it. I have a few trannys but you are a long ways away. We are having a transmission tech shop this weekend I think, or is it the following weekend, nope, it's this weekend. Should be interesting.
jet1 |
Jun 29 2005, 12:38 PM
Member Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) and take your time. Good luck!
fatlando |
Jun 29 2005, 12:39 PM
Scott, thanx alot for the advice..took a look at your gallery, and looked at your cars in the driveway and noticed your mufflers were trying to hide in the bushes.....how far did they get before you caught them??? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
d7n7master |
Jun 29 2005, 12:58 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
You might want to disconnect the axles before you drop that engine. ------ I used wire coat hangers to hold the axles UP & out of the way, and plastic bags over the CV joints to keep the grease out of my hair. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) ------ And, listen to me now - believe me later - 2 hydraulic jacks, one on each side, and Schweet - Git-R-Done (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
skline |
Jun 29 2005, 01:04 PM
The little bastards actually got away, I kept bringing them back in the garage but they are sneaky and slipped away. From now on, I put them in the back of the garage for safe keeping. (IMG:http://www.914world.com/bbs2/html/emoticons/owned.gif) |
redshift |
Jun 29 2005, 01:10 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
My mufflers are password protected.
M |
zymurgist |
Jun 29 2005, 02:11 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
FWIW... when we dropped Babydoll's engine, we wrapped the CV joints with Saran Wrap and plastic bags and taped it all in place to keep dirt out of the grease, and then bungied the axles up. Then I took a length of PVC pipe and stuck it between the ends of the axles (the pipe was big enough so the CV joints would slide into it), and bungied the pipe up. We did this so we could roll the car out of the garage, because I needed that bay for storage.
MoveQik |
Jun 29 2005, 02:21 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I had never dropped an engine before. I used Pelican's how-to and it came out in about 2 hours. Not bad for a first time! Getting it back in was another story. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
I threw in the towel and finally had a shop do it. |
joeav8tor |
Jun 29 2005, 04:05 PM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
I dropped my engine for the first time a couple of months ago...it took a couple of hours to get out, and went back in relatively easy...I had one friend help me...and followed the pelican article....only I had jack stands on the jacking doughnuts, removed the rear valence, and used two jacks to drop the motor, one jack was used to help keep the motor and tranny level...dont forget to remove the tranny grounding strap...and have a couple of friends help pull up on the fuel rails so they dont get hung up...take your time, if you run into any problems...email your question...it is not too hard.
good luck! (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) Joe Attached image(s) |
joeav8tor |
Jun 29 2005, 04:07 PM
pic
Attached image(s) |
joeav8tor |
Jun 29 2005, 04:10 PM
after
Attached image(s) |
rhodyguy |
Jun 30 2005, 09:49 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
lando, hope this isn't too late. spray every nut down with pbblaster 1 or 2 days prior to. go to homedepot and get 1 of the $18 funiture dollies. slightly loosen the bolts on the engine and trans while it's in the air, this is easier than fighting them when the car is lowered. as you lower the car to the dolly, you will note that the angle of the engine/car will leave a few inches unsupported at the front of the dolly. a piece of 2x4, or whatever, will fill the space so there is no "drop" as you get ready to finnish the removal. when you are ready to go, get 2 pieces of tin or license plates and slide them inbetween the fuel rails and the engine shelve. this will help keep the fuel rails froms getting hungup on the suspension ears.
k |
fatlando |
Jun 30 2005, 10:33 AM
hey kev, thanx alot.... i'm a little nervous, but i've got to know my car sooner or later right.?? stand by for my post that goes.... "It's out....now what??????" (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 01:04 PM |
