901 dissasembly, how do i get gears off the shafts? |
Aaron Cox |
Jul 9 2005, 03:30 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
taking apart old 901 four speed. i need the S gear out of it and the HB gear. i have the whole thing apart.... got the nut off the main shaft, but cant get the bearing to budge.
how do the gears come off? how do the sghafts come off the input shaft????? AA |
TimT |
Jul 9 2005, 03:31 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
a press grasshopper
Aaron Cox |
Jul 9 2005, 03:37 PM
F#CK.... i saw dr evil did it without a press..... how the fuck... |
TimT |
Jul 9 2005, 03:44 PM
Or support the gear stack vertically, between the jaws of a vise on a sturdy workbench.
Take a block of wood to protect the end of the shaft and beat away with a BFH You should be able to drive the shaft out of the gear stack. I then go over the input/output shaft with some crocus/emory cloth and reduce the amount of interfernce between the gears sliders spacers etc.. so you dont need a press or BF next time around... The guy whose name escapes me now.. he rebuilds the trannys for PMNA showed me this trick |
TimT |
Jul 9 2005, 03:45 PM
Even that mod to make the gears slide more easily on and off needs a lil more splainin
you really should chuck the inpu/output shaft in a lathe to do this |
Aaron Cox |
this is an early aluminum 4 spd....
i cant even get the shafts out the input shaft yet.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) BTW - what are EARLY 4 bolt 2 Pin output shafts worth? |
Aaron Cox |
Jul 9 2005, 03:47 PM
dont care about the A-gear mainshaft. just want the gears off of it....
and the layshaft gears too.... anyone need an AL case? |
Red-Beard |
Jul 9 2005, 04:10 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Did you even read my article?
BFH. Use a brass one and be gentle, but forceful. |
Bleyseng |
Jul 9 2005, 04:13 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Go buy a $20 BRASS BFH (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) and beat the shafts out of the bearings. Once out the gears slide off. Remember, brass is soft, steel is way harder! |
jr91472 |
Jul 9 2005, 04:17 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
I used one of those gear puller/bracket things like a press. Worked like a charm by pushing the shaft out of the intermediate plate.
I can take a picture if you want |
Aaron Cox |
Jul 9 2005, 04:55 PM
used a BFH and a brass rod.
out like a charm. now have HB S Z gear sets bundled together.... sliders/dogteeth/synchros look pretty good. now to have someone assemble my other 914 box... A F ZD Flipped S ZD BTW - what are the output shafts worth out of this box -4 bolt 2 pin, a little bigger than stock 914 stuffs |
Bleyseng |
Jul 9 2005, 06:00 PM
put it together yourself Aaron. you can do it, you are a adult now. (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif)
bondo |
Jul 9 2005, 06:11 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
No idea what those output flanges are worth. If they are like the 912 trannies I took apart, they're different and wouldn't fit a 914 trans.
ClayPerrine |
Jul 9 2005, 07:56 PM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Use the HB flipped for 5th. It gives more overdrive..... What you end up with is a close ratio 4 speed with a long legged 5th for highway use. |
Aaron Cox |
Jul 9 2005, 09:24 PM
too tall i believe. more suited for a v8. not enough torque from a four banger....
and the gap from an S 4th to a flipped HB 5th would be huge! imagine that downshift... waaaoooo weeeeeeeeeeee |
Joe Bob |
Jul 9 2005, 09:32 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Amazing what happens when ya RFTFB....gud boy....
ClayPerrine |
Jul 9 2005, 09:38 PM
Actually, that's the exact gear set I have for my /6 conversion.... Recommended by 2 long time Porsche people, each not knowing of the other's recommendation. As soon as my car is on the road I will let you know how it works! (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Aaron Cox |
Jul 9 2005, 10:32 PM
rftfb? |
Dr Evil |
Jul 9 2005, 10:43 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Did ya get them off? I tried to call you, but you didn't answer your phone.
Aaron Cox |
Jul 9 2005, 11:36 PM
got em all off, thanks for the guidance on the phone mike AA |
Lo-Fi Version | Time is now: 7th June 2024 - 11:33 AM |
