Beakster |
Member ![]() ![]() Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None ![]() |
Hey Guys Post a Picture of What Color you Painted your Tin ... Other then the Gloss Black
(IMG:style_emoticons/default/beerchug.gif) |
rgolia |
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,060 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Hey Guys Post a Picture of What Color you Painted your Tin ... Other then the Gloss Black (IMG:style_emoticons/default/beerchug.gif) Original was a satin black. I like it painted the cars color. Black makes it hard to see all the hoses and wires. |
Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,905 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Good ol gloss appliance white on my old CIS engine.
Attached image(s) ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,992 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Satin black. Usually the easiest and cheapest to get done at the powder coating companies since they can add it in on the side to a larger order.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
SO.O.C914er |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,633 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California ![]() |
I agree with Bruce! Did mine in metallic blue as close to the color of the car. I like the yellow and the white looks sharp only concern is lite colors will show the dirt sooner?
Beakster |
Satin black. Usually the easiest and cheapest to get done at the powder coating companies since they can add it in on the side to a larger order. Just had three sets done a couple months ago. Powdercoat is the best, as it's least effected by spilled gas. Hey . ... Mark .. What dose the Satin black look like .. Any Pictures?? |
mepstein |
Satin black. Usually the easiest and cheapest to get done at the powder coating companies since they can add it in on the side to a larger order. Just had three sets done a couple months ago. Powdercoat is the best, as it's least effected by spilled gas. Hey . ... Mark .. What dose the Satin black look like .. Any Pictures?? Pretty much the same as all the black on the car. Suspension, dash, steering wheel spokes, rocker panels, etc. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Jett |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,684 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest ![]() ![]() |
Looks very clean! I just delivered some tin to be powder coated black and will be looking for guidance on all the required grommets (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
Satin black. Usually the easiest and cheapest to get done at the powder coating companies since they can add it in on the side to a larger order. Just had three sets done a couple months ago. Powdercoat is the best, as it's least effected by spilled gas. Hey . ... Mark .. What dose the Satin black look like .. Any Pictures?? Pretty much the same as all the black on the car. Suspension, dash, steering wheel spokes, rocker panels, etc. (IMG:style_emoticons/default/agree.gif) close to OE flat black but it does have a little bit more sheen. Once in use it should look correct. |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,262 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Looks very clean! I just delivered some tin to be powder coated black and will be looking for guidance on all the required grommets (IMG:style_emoticons/default/smile.gif) I like the makeshift engine stand. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
semi gloss black to dissipate the heat
Hey Guys Post a Picture of What Color you Painted your Tin ... Other then the Gloss Black (IMG:style_emoticons/default/beerchug.gif) |
Mark Henry |
semi gloss black to dissipate the heat Hey Guys Post a Picture of What Color you Painted your Tin ... Other then the Gloss Black (IMG:style_emoticons/default/beerchug.gif) Myth, well maybe there's a couple percent of truth depending more on the pigment type, but that's it. Most heat from the engine is infrared and transferred by convection not radiation. Paint colour has little to do with heat transfer (infrared). |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
You Can get powder coat in custom colors.
ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,176 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
HansJan |
Member ![]() ![]() Group: Members Posts: 401 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region ![]() ![]() |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,466 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Oops.
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Deja vu thread, we just had one of the same. It's satin black powder coat to be correct and withstand the torture, or it's whatever you want. Bright is nice for visibility, color coordinated is cool to an extent. If you deviate, do what you want. Surprised nobody has chromed a set by now. (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 31st July 2025 - 05:42 AM |
