buying front mount oil cooler, fluidyne, single pass or double pass |
pete-stevers |
Aug 8 2005, 07:45 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
which should i buy for a 3.0 application (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
TimT |
Aug 8 2005, 08:06 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Buy the biggest cooler that fits within your cars constraints
seanery |
Aug 8 2005, 08:08 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
do the multiple passes help much?
TimT |
Aug 8 2005, 08:10 PM
I have a DB30417 mounted centered on my 911
and have used the DB30618 on some seriously high powered 911s |
pete-stevers |
Aug 8 2005, 10:51 PM
are the coolers double pass or single pass?? and which is better??
retrotech |
Aug 8 2005, 10:53 PM
retrotech Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 |
I have the double pass Fluidyne.I haven't had it on the track, but driving fairly aggeressive in 90+ degrees, it never got over 190.
I love it! |
xitspd |
Aug 8 2005, 10:57 PM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) The bigger the better! Attached image(s) |
brant |
Aug 9 2005, 08:49 AM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Pete,
I,m running a pair of the double pass fluidyne's. We even had to block off 2/3rds on one side with a piece of plastic that fits infront of it. but I would much rather have excess cooling rather than inadequate cooling. We fought oil temps for 6-8 years in our 4 cylinder car when we added the 2nd driver. I promise it is easier to block off with tape or what ever and then have the ability to increase later. plus if you run a thermostat then it will be regulated for you. We don't run a thermostat right now since it is a race only application: Attached thumbnail(s) |
seanery |
Aug 9 2005, 10:09 AM
Hey Brant, what is the flow of your coolers? Are they in series?
brant |
Aug 9 2005, 12:02 PM
Sean,
yep... in series. everyone is clear that they are not as effecient in series as they would be/could be. but it works well for plumbing purposes to go up one heater duct and then back to the stock tank on the other side of the car. here is the missing hose that makes them in series: Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:38 PM |
