ILM914 |
Member ![]() ![]() Group: Members Posts: 104 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None ![]() |
hey guys I bought a 74 2.0 that needs restoration and the seller has no keys. he has blanks. Is the best way to make an ignition key to remove the driver side or passenger side door handle and bring it to a locksmith? Thank you, Joe
fiacra |
Person.Woman.Man.Camera.TV ![]() ![]() ![]() Group: Members Posts: 580 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California ![]() ![]() |
Unfortunately there is no knowing if the keys to the doors, or the keys to anything else on the car, match the key to the ignition. If you think the ignition is original probably your best chance is to bring in the lock cylinder from the frunk release handle to get a key made. You can also try the glovebox lock. Both of those are less likely to have been changed. I would seek advice from @thecabinetmaker Good luck!
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,346 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Front trunk is the easiest to remove, if it's unlocked. Glovebox, not so much. Door handles have most likely been changed. If you're doing a restoration, just pull the ignition switch.
totle |
Newbie ![]() Group: Members Posts: 43 Joined: 18-October 10 From: Norway Member No.: 12,280 Region Association: Europe ![]() |
has started this prosess on mine as well.
As I installed a 911 ignition I started with the ignintion, and then will do the rest. Was able to finally find a firm that sold me the tumblers |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,516 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Here's a link to assist with getting the various bits out.
http://www.914world.com/specs/rekey.php Once these are removed, the "ez button" is shipping it all to Curt (TheCabinetMaker) to get 'er done all in one shop. That's why the first reply taggged him in to this thread (but we try to avoid doing that three times in a row, 'cause we don't know what'll happen...) |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,198 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Have the ignition switch done first and try all the locks. You may get lucky and several of the locks may be original. Usually the hood pull and glove box will be stock.
ILM914 |
Thanks guys the car looks very original and unmoleste. 58,000 orig miles I don't think the locks have changed. The seller is doing this for me before he ships the car. I don't think he can remove the front trunk handle and lock. should he try the door handle to a locksmith?
914Sixer |
Door handles are a pain to remove and has to be done in the right sequence.
ILM914 |
Thanks door handle is one nut to remove what am I missing guys thanks
TheCabinetmaker |
There's another bolt inside the door. Door panel must be removed for access to it.
Rusty |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,976 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States ![]() ![]() ![]() |
There's another bolt inside the door. Door panel must be removed for access to it. Curt is correct. 6mm socket head? Best to roll the window up, get a flashlight and peer up into the door to get a look at it. When you're reassembling, mind the outer gasket. They have a tendency to shift around while you're fiddling with it from the inside. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,049 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
bdstone914 |
There's another bolt inside the door. Door panel must be removed for access to it. Curt is correct. 6mm socket head? Best to roll the window up, get a flashlight and peer up into the door to get a look at it. When you're reassembling, mind the outer gasket. They have a tendency to shift around while you're fiddling with it from the inside. It is a 6mm allen head bolt and needs a 5mm Alken wrench. |
bdstone914 |
I think the rear trunk lock is the easiest to remove. They dont get changed that often and you probably want a key for it too. If your lucky it will mmn atch other locks.
914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I took all my lock cylinders to a local locksmith and he had no issues changing them all out to be the same. I would think any good locksmith would be able to do this for you. I'm glad I did it; I had 4 different keys at one point.
Lo-Fi Version | Time is now: 19th July 2025 - 06:53 AM |
