Best lubrication for pedal board/clutch cabal wheel, Grease, graphite, oil , silicone, ?? Which is best and why?? |
second wind |
Nov 18 2023, 10:23 AM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Good morning out there.....so I have cleaned up my pedal cluster and have a new clutch cable to install......grease makes everything move so nice but attracts dirt and grit...I even made a clutch wheel cover since the wheel is so close to the ground....I believe it worked pretty well.....what do you guys use to keep things moving nice and clean??
Thank you, gg |
NARP74 |
Nov 18 2023, 10:27 AM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I just heard of this stuff. Have not tried it yet, but will investigate further.
https://www.inoxmx.com/products/mx4-lanox-lanolin-lubricant/ |
Flyinlow |
Nov 27 2023, 03:40 PM
Flyinlow Group: Members Posts: 36 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada |
I just heard of this stuff. Have not tried it yet, but will investigate further. https://www.inoxmx.com/products/mx4-lanox-lanolin-lubricant/ This might sound crazy but… non stick cooking spay keeps grime and sand from accumulating on rv jacks and I’ve had good success with it (IMG:style_emoticons/default/WTF.gif) |
87m491 |
Nov 27 2023, 03:44 PM
Member Group: Members Posts: 275 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Good morning out there.....so I have cleaned up my pedal cluster and have a new clutch cable to install......grease makes everything move so nice but attracts dirt and grit...I even made a clutch wheel cover since the wheel is so close to the ground....I believe it worked pretty well.....what do you guys use to keep things moving nice and clean?? Thank you, gg Doesn't the clutch cable come in a low friction sheath? How many decades did the previous one last? I'm hesitant to over lube or over think cables, but then I live in the northeast where lube in the summer can be friction device in the winter. BTDT. |
second wind |
Nov 27 2023, 07:51 PM
Good morning out there.....so I have cleaned up my pedal cluster and have a new clutch cable to install......grease makes everything move so nice but attracts dirt and grit...I even made a clutch wheel cover since the wheel is so close to the ground....I believe it worked pretty well.....what do you guys use to keep things moving nice and clean?? Thank you, gg Doesn't the clutch cable come in a low friction sheath? How many decades did the previous one last? I'm hesitant to over lube or over think cables, but then I live in the northeast where lube in the summer can be friction device in the winter. BTDT. Thank you very much for your reply! After 12 or so years of crawling under these cars....and me being 12 or so years older...I am just thinking out loud....less tends to be more so I may skip any type of lubrication...especially any "wet" lubes like grease...graphite is appealing to me though.....dry and slippery....thank you! gg |
JamesM |
Nov 28 2023, 02:22 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I just heard of this stuff. Have not tried it yet, but will investigate further. https://www.inoxmx.com/products/mx4-lanox-lanolin-lubricant/ This might sound crazy but… non stick cooking spay keeps grime and sand from accumulating on rv jacks and I’ve had good success with it (IMG:style_emoticons/default/WTF.gif) works well on the underside of lawn mower decks as well. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:29 AM |
